Old 09-22-2014, 09:19 PM   #1
POPO1984
POPO1984's Avatar
Glove box won't latch
Am i missing something here. Seems that my glovebox is mounted wrong or something. The latch is not high enough to catch.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 09-22-2014, 09:20 PM   #2
POPO1984
POPO1984's Avatar
Re: Glove box won't latch
another pic
South Houston
Old 09-22-2014, 09:21 PM   #3
POPO1984
POPO1984's Avatar
another
South Houston
Old 09-22-2014, 09:32 PM   #4
Grumpy old man
Grumpy old man's Avatar
add a spacer to the hinge and be done with it ! it worked when you took it off did it not ? OMG.
Old 09-22-2014, 09:41 PM   #5
hamjet
hamjet's Avatar
the cardboard liner gets sandwiched under the door. that should raise it up enough..
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-22-2014, 10:09 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Did you add the locking latch or has it always been on there? How about a picture of the back of the lock.
LockDoc
Leon
Old 09-22-2014, 10:54 PM   #7
Andy4639
Old member
Andy4639's Avatar
Question Re: Glove box won't latch
The part on the dash can be adjusted also a little. Take the screws loose and let it drop down as far as it can. The cardboard insert should be between the glove box door and dash as mentioned.
You picture is missing the side bar also that stops the door when you open it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-23-2014, 09:46 AM   #8
POPO1984
POPO1984's Avatar
I'll order the glove box liner and get a pic of the lock. I had three doors and the painter lost the one that went to this cab so this one is now of my spares
South Houston
Old 09-23-2014, 09:47 AM   #9
POPO1984
POPO1984's Avatar
Do I get the glove box with or with out ac. I won't have factory ac but will have vintage air.
South Houston
Old 09-23-2014, 09:57 AM   #10
leftybass209
leftybass209's Avatar
Vintage air uses its own plastic formed glove box.
leftybass209 is offline   Reply With Quote
