Old 07-27-2008, 01:28 PM   #1
chevymotocross
chevymotocross's Avatar
Is this why transmission fluid is leaking from my yoke?
I have an 87 2wd with the 700r4. Whenever I park the truck on a hill, I get a massive leak out of the weep hole on the driveshaft yoke. I found on 73-87.com, the reason why this happens and how to fix it (http://www.73-87.com/7387garage/drivetrain/yokeleak.htm). I pulled the tailshaft off, and I did not find the cup which includes the o-ring at fault. I believe this is the reason why it's leaking. I remember the previous owner saying the transmission was overhauled or replaced, can't quite remember. This could be why. So I'm assuming it is suppose to have this according to 73-87.com? Where can I find this cup? I already have the o-ring.
The cup with o-ring which I guess I should have
My assembly, as you can see, no cup:
chevymotocross is offline   Reply With Quote
Old 07-27-2008, 03:57 PM   #2
LONGHAIR
Re: Is this why transmission fluid is leaking from my yoke?
Local transmission shop? Chevy Dealer? Boneyard?....whichever is easier or most convenient.
LONGHAIR is offline   Reply With Quote
Old 07-27-2008, 04:10 PM   #3
chevymotocross
I'm going to try a local transmission shop this week. I'm glad I found that article, otherwise, I would have never figured out why it was leaking. Not only did whoever rebuilt/replaced the transmission forget that cup, they also didn't put the flywheel/torque converter shield on.
Old 07-27-2008, 04:15 PM   #4
LONGHAIR
That is pretty common, along with starter supports, and the support rods that went from the transmission up to the motor mount area...stuff gets left off.
Old 07-27-2008, 04:26 PM   #5
gafiredog
chevymotocross, i had this problem on a 79 c-20 with a 350 turbo. i had the trans. rebuilt, and after i picked it up, it leaked bad out of the yoke, i took it back to the trans. shop & they said the plug had been knocked out in the rebuild process, as well as i remember, the hole was about the size of your little finger. they took the driveshaft out, and put silicon in the hole, that stopped the leak, hope this helps in some way, Art
Art
1975 c-10 stepper
1978 single cab dually
1987 crewcab dually
1986 crewcab single wheel
1948 anglia- (the dixie twister super gas)
gafiredog is offline   Reply With Quote
Old 07-27-2008, 04:37 PM   #6
LEEVON
Moderator
LEEVON's Avatar
I had the same problem so I went to the junkyard and found a cup, but couldn't get it off the shaft. It felt like if I had used a puller it would have gotten damaged. The only place I could find to buy the cup is the dealership but the parts counter guys are jerks about small stuff and I didn't feel like going through that dance with them. Same with the trans shops (no se hablan englais).
Nore more messing with that, I just plugged the tailshaft hole with a screw.
Not my favorite way of doing things but it works and is free.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 07-27-2008, 05:50 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Weld it, glue it, or screw it, whatever it takes. It's a lot easier to plug the hole in the yoke, and net the same results.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-30-2008, 07:38 PM   #8
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
look at the yoke on the drive shaft its self (does it have a weep hole (tiny hole in the back of yoke (my truck did simalar stuff and that was the problem.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 07-30-2008, 08:52 PM   #9
chevymotocross
Yup, that's where it's leaking from. I stopped by local transmission shops, they all said the same thing "plug it". No one had that cup and seal so that's exactly what I did. I put jb weld over the weep hole, let it dry, parked it on the steepest hill I could find and......... NO MORE LEAKS!
Old 07-31-2008, 12:36 AM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
My bro-in-law builds transmissions for a living. He built the 700r4 that we put in my 77 during my Ramjet conversion. He didn't realize I had a yoke with the vent hole so it leaked. He installed the cup, and seal and it still leaks. When I told him that it still leaks he said plug the hole and forget about it.
Articles-
"Refining Sierra"
Old 01-22-2013, 12:34 PM   #11
JoeyBones
bringing this back from the dead.... has anyone used something like this to fix this:
http://www.teckpak-fitzall.com/datasheets/35746ys.pdf
I ordered the oring/cup parts to try it, but if they dont work...its getting sealed up one way or another.
JoeyBones is offline   Reply With Quote
Old 01-22-2013, 03:04 PM   #12
LEEVON
Moderator
LEEVON's Avatar
I guess if it was cheap...otherwise just hit it with a shot of brake cleaner, let it dry and dab some black rtv in the hole. Or JB weld, or a tiny machine screw. Any of the above will make it stop.
I still remember coming out to my truck parked on an incline in the driveway and fluid was all the way down into the gutter. DOH.
Old 04-06-2013, 07:55 PM   #13
1955 mancave
1955 mancave's Avatar
yep same problem here so i will now pull the driveline and see if i can plug that darn hole.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 04-08-2013, 02:23 PM   #14
Rich84
Rich84's Avatar
Tranny builder I know said to put some silicone on a thumb tack and stick it in the whole..
Rich84 is offline   Reply With Quote
Old 04-08-2013, 02:50 PM   #15
BIG DADDYS 84
most common leaks with th350 at yoke is from front yoke,extension housing bushing being worn. due to wear or misalignment of pinion angle. most time replacing extension housing bushing and seal will fix this. small hole at rear og extension housing is for lubing yoke and bushing.this hole needs to be open or will cause bushing failure
BIG DADDYS 84 is offline   Reply With Quote
Old 04-08-2013, 02:57 PM   #16
BIG DADDYS 84
WOOPS, had 350 on the brain
Old 04-08-2013, 03:42 PM   #17
1955 mancave
well today , this is what i did , i went to ace hardware i found a body trim plug that was slightly larger than the hole put some RTV on it and pushed it in, i looked after about an hr and it seems to be pretty solid and no sign of leaks.
we will see if it holds up down the road.
Old 06-25-2015, 02:07 PM   #18
Sierra 1
Same problem here so glad somebody knows how to stop the leak...Thanks to all
Sierra 1 is offline   Reply With Quote
Old 07-01-2015, 01:16 AM   #19
Mtrhd329
If i remember correctly a bud light bottle cap has almost the same spline count and diameter as the inside of the yoke. Little rtv and a cap and your good
Mtrhd329 is offline   Reply With Quote
Old 07-01-2015, 10:37 AM   #20
Sierra 1
Thanks, This seems to be the best fix...I simply dripped about 1/4 inch of hot glue into the open end of the yoke and allowed it to cool..No leak..
