Old 11-08-2014, 11:35 PM   #1
Paul83
Paul83's Avatar
Water temperature Gauge
I am having a problem with my factory temperature gauge. It is staying on the cold side and will not move. I have tried the grounding it out method and it did not move so I tried an extra temp gauge I had and it did the same thing. (needle did not move) I can't think that both gauges are broken and I have put on 2 separate temperature sending units nothing. I also tested the ohms on the ceramic piece behind both of the gauges and they are both reading 84 ohms. I have installed electric fans recently. I don't think the engine temp is staying below 100 degrees. Is there a wiring issue somewhere. Maybe I don't have it grounded good enough what do you think? All the other gauges work except my gas gauge. I am not sure if they are related or not. Any thoughts or input is helpful. Thank you.
I don't care how old or gangster you think you are; if a 3 year old hands you a play phone you answer that!
I like long walks on the beach, dinner by candle light, and poking dead things with a stick.
Paul83 is offline   Reply With Quote
