Old 12-19-2014, 07:29 PM   #1
of13swc
rear end carrier question?
Is there a difference between a stock carrier in a stock 12 bolt in a 65 and one if the rear end has 4.10 gears?
of13swc is offline   Reply With Quote
Old 12-20-2014, 12:48 AM   #2
Captainfab
60-66 Nut
Re: rear end carrier question?
A stock '63-'82 truck 12 bolt could have 4.10 gears. To more specifically answer your question, the 3.73 and lower gears use a 4 series carrier and the 3.42 and higher gears use a 3 series carrier. You can get aftermarket thick 3.73 and lower gears that will work on the 3 series carriers.
Old 12-20-2014, 02:36 PM   #3
of13swc
I have already bought the gears. So where can I get a series 4 carrier? Without spending a bunch of money
Old 12-21-2014, 01:06 AM   #4
Captainfab
60-66 Nut
From any '63-'82 truck 12 bolt that has 3.73 or lower gears.
