Old 10-25-2014, 02:41 PM   #1
87R10Coming
One injector working
How do I repair an injector that's not spraying, is it a electrical problem or just need to replace it?
87R10Coming is offline   Reply With Quote
Old 10-25-2014, 03:58 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: One injector working
Swap injector plugs. That's how I checked mine. The wires are long enough to plug into either. It was clogged so I got another one.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-25-2014, 06:47 PM   #3
87R10Coming
I will try that
Old 10-26-2014, 10:43 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Get an ohm meter and ohm out the pins on that injector and compare it to the other injectors. Injectors can usually be overhauled at an injection shop for around $40-60 each, depending on the shop.
Old 10-26-2014, 11:19 AM   #5
Just call me Sean
Other injector, there's only two. So that wouldn't help as much as it would if there were eight to compare.
Old 10-26-2014, 01:09 PM   #6
greg64
greg64's Avatar
I think, from memory, that a low impedance TBI injector will measure around 4 ohms. Also, with the ignition key on, one of the two wires that goes to each injector will be 12V hot. The ecu grounds the other wire to open the injector. And, if you point a timing light at the injector with the engine running and the air cleaner off, you can visually see the spray pattern.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 10-26-2014, 04:12 PM   #7
87R10Coming
I swap plugs on the injectors and it's still not working
Old 10-26-2014, 04:55 PM   #8
Just call me Sean
It's clogged. I got a whole throttle body at the junkyard for $25 and used an injector from it, but new ones I priced at about $60 each at AutoZone.
Old 10-26-2014, 06:45 PM   #9
87R10Coming
Going to change it... Thanks for the help
87 r10
