Old 08-15-2003, 10:52 PM   #1
Lizard
Post Carb Adjustments?
Can anyone tell me if there are any adjustments I might need to make to my carb after putting on Dual exhaust... The 350 ran great before doing this job, and now when the secondaries open the engine backfires and falls on its face. Any Ideas?
Lizard is offline   Reply With Quote
Old 08-15-2003, 11:08 PM   #2
COBALT
COBALT's Avatar
Whenver you do anything with fuel consumption or emissions always check your ignition, your timing, and yes your fuel/air ratio. Your engine timing might be a tad retarded (opposite of advanced), which means a few extra degrees of advancement may be all you need.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-16-2003, 08:19 PM   #3
Lizard
Thanks Alot, I checked the timing and it was 8 degrees retarted. I put it up to 6 BTC. It runs great. Thanks for the info..
