Old 11-13-2014, 05:35 PM   #1
hotrod9454
Rear end swap
I have a 72' step side with a leaf spring rear end and would like to convert over to coil spring. Does anyone know how to do this properly, got any pictures or links to go to help me out? What has to be added or removed, cross member for trailing arms, brake lines, etc.
hotrod9454 is offline   Reply With Quote
Old 11-13-2014, 09:50 PM   #2
gale
Re: Rear end swap
I'm just now thinking of parting out my '67 stepped LWB and the trailing arms are in great shape.
I need to focus on my '54 3100.
Gale Gorman
'54 3100
'67 C20 stepside
gale is offline   Reply With Quote
Old 11-13-2014, 10:05 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear end swap
Hi Bill,
You would have to get a trailing arm center crossmember, trailing arms, coil springs, track bar, and track bar frame bracket. The spring perches are different so you would have to cut your perches off and weld on the coil spring perches or swap rear axles. I'm probably missing something but some of the other guys will save me if I am.....
Oh yes, I think the small crossmember behind the rear axle is different too.
LockDoc
Leon
Old 11-13-2014, 10:23 PM   #4
hotrod9454
Re: Rear end swap
Lock Doc, Thanks for the info. I found a good set up in a wrecking yard with all the parts ( I think) to do the swap.
Should I be able to use my old brake lines. I would be changing the whole rear axle at the same time.
Old 11-14-2014, 01:53 AM   #5
mechanicalman
Re: Rear end swap
If you use your old brakes, you can use your old brake-lines for sure and still likely if you don't. You could actually remove the backing plates and all and never break open a brake line or not remove a brake spring just transfer them over to the new rear-end just hang them with coat-hangers.
I expect the lines would fit if it's a 71-72 5 lug rear end.
mechanicalman is offline   Reply With Quote
Old 11-13-2014, 11:49 PM   #6
michael bustamante
michael bustamante's Avatar
Re: Rear end swap
Shock mounts are different too arent they? ( uppers )
1967custom
michael bustamante is offline   Reply With Quote
Old 11-14-2014, 01:57 AM   #7
mechanicalman
Re: Rear end swap
Good idea to check that one! Something else to chisel off that old frame after hands are numb chiseling off that cross-member! LOL been there, done that.
Old 11-14-2014, 04:15 PM   #8
hotrod9454
Re: Rear end swap
Thanks for all the help guys, but I think I will just go with 5" lowering leafs, sounds much easier and cheaper.
Old 11-14-2014, 05:20 PM   #9
LockDoc
LockDoc's Avatar
Re: Rear end swap
Wise choice as far as I'm concerned...
LockDoc
Leon
Old 11-14-2014, 01:31 AM   #10
sierragrande71
sierragrande71's Avatar
Re: Rear end swap
Not to hijack hotrod9454's thread but I see that your from Elk Grove, I use to live and work there for 8 yrs. anyways I'm also looking for some info as to how to do this on my 2wd converted blazer.
sierragrande71 is offline   Reply With Quote
