Old 11-16-2014, 10:52 AM   #1
JGood
JGood's Avatar
Brake issues!!!
I'm having issues bleeding the brakes on my 86 1/2 ton wrangler. I got the back brakes to bleed and when I went to start in the front once they got a bit of fluid they lock up and don't seem to want to unlock. I've changed the master cylinder and the proportion valve on the frame and it doesn't seem to have helped and I've even taken the calipers off and pushed the piston back in and they don't take much effort to push back into place. I don't think it could be the calipers as both sides lock up. Any advice would be greatly appreciated.
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 11-16-2014, 11:14 AM   #2
bilfman
bilfman's Avatar
Re: Brake issues!!!
Calipers can get sticky and not release. Rust and heat can cause them to run tight and not release. I would assume that is the issue, as you mentioned both sides that is odd but not out of the realm of possibilities. I have had to brush an file to fix this in the past or calipers are cheap to replace.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 11-16-2014, 11:17 AM   #3
JGood
JGood's Avatar
Re: Brake issues!!!
Ya it's just weird that when I had them out on the bench the piston compressed without much effort and when I put it back on the slides were loose even.
Old 11-16-2014, 11:31 AM   #4
ssxty8
Lightbulb Re: Brake issues!!!
Clogged brake lines??
ssxty8 is offline   Reply With Quote
Old 11-16-2014, 11:48 AM   #5
Houston Ben
Houston Ben's Avatar
Re: Brake issues!!!
I had a similar problem one time, the brake bleed screw was totally clogged with rust and crap!
Houston Ben is offline   Reply With Quote
Old 11-16-2014, 11:51 AM   #6
JGood
JGood's Avatar
Re: Brake issues!!!
I know they aren't clogged because I've got some brake fluid coming out. Would the proportion valve be causing issues?
Old 11-16-2014, 01:42 PM   #7
ssxty8
Re: Brake issues!!!
By previous experience, I noticed that a semi clogged brake line can let fluid in, due to the high pressure applied by the hydraulic system as you push the pedal, but it's not so free as to let fluid return back by itself. If you disconnect the line/s from the caliper, can you see it dripping fluid by gravity? it should.
Bruno
Old 11-16-2014, 11:04 PM   #8
JGood
JGood's Avatar
Re: Brake issues!!!
Well it's for sure one clogged line on the passenger side and I'm not sure about the caliper but I think I might put new ones on anyways and then every base is covered I guess.
Old 11-17-2014, 09:36 AM   #9
mrolds88
Re: Brake issues!!!
I have had the inner liner deteriorate and cause issues. They can get a "flap" and shut off the flow of fluid. Loosen the line at the entrance of your rubber lines on the front to see if you are moving fluid well to that point.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-17-2014, 09:45 AM   #10
JGood
JGood's Avatar
Re: Brake issues!!!
Yeah I un did both ends of the steel line and blew through it fine just that stupid rubber line causing all my issues I think and a calliper because even unhooked it wouldn't release and had to pry it off
Old 11-20-2014, 01:35 AM   #11
JGood
JGood's Avatar
Re: Brake issues!!!
Does anyone know what style of brake system it would have? Jb?
