Old 11-18-2014, 11:10 AM   #1
blazer2007
what to spray inside new wheel tubs ?
I got my new floor and wheel tubs done and was wondering what to use inside the wheel tubs and under floor to help with noise etc.Gravel guard,bedliner or ?.Is on a 78 blazer weekend driver.I will be using some sorta insulation on the inside of the blazer but thought if I have to paint the underneath I might as well use some extra sound deadening
blazer2007 is offline   Reply With Quote
Old 11-19-2014, 07:43 AM   #2
tobiahr
tobiahr's Avatar
Re: what to spray inside new wheel tubs ?
I've heard good things about Lizardskin for sound control on exterior surfaces. Sort of unrelated but I have heard of coating the undercarriage with WD40 prior to wheeling to make cleanup easier. It also helps keep road salt from building up.
tobiahr is offline   Reply With Quote
Old 11-19-2014, 10:10 PM   #3
68Timber
I know the pieces fit
68Timber's Avatar
Can you undercoat with lizard skin products? I thought they were designed to go on inside the tub.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-19-2014, 10:28 PM   #4
tobiahr
tobiahr's Avatar
According to their website it is good for exterior surfaces and helps with moisture control.
http://www.lizardskin.com/off-road-v...nsulation.html
" Since both coatings are tough and durable, they can be used as an undercoating to protect fenders and wheel wells from starring and denting from rocks kicked up from the tires. "
