![]() Join Date: Feb 2001
which original key in 1967?
Did '67 trucks use the 60's Briggs 6 sided key or the larger 4 sided key that was
used in the 70's-80's? JQ
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
18 Till I Die
Re: which original key in 1967?
I had a 67 once and it came with the 6 sided key.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
![]() Join Date: Apr 2013
My '67 has the octagonal B&S keys.
![]() Join Date: Sep 2007
Octagon key
1967custom |
Thanks for you help. I just acquired a 67 swb from original family. The truck had been sitting a while and the key was lost. I'm going to pull one of the door locks and take it to a locksmith for him to recut a new key - just needed to know which style.
Joshua
#6 | |
The Older Generation
Start with the passengers side door lock. As the guys have said, the ‘67’s originally came with the Octagon key. It uses the “A” keyway and the original blanks can be hard to find. The later style rectangular head “A” key blank will also work in it. When GM went to the dished ignition bezel in ’67 they didn’t think about the octagon key being recessed and hard to turn. The dealerships received a lot of complaints about it so GM changed the key design to the rectangular head. Some early ‘68’s came from the factory with small octagon head key also. They used the "C" keyway blanks. The key code will be located on the door lock as shown in the picture and will always be stamped into the lock case. Also remember that the '67's and some early '68's did not have an accessory position on the ignition switch.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-01-2014 at 08:25 PM. |
Learn something new everyday. My '67 has the square key. Looks like I have to add something else to my list.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
OK, I had some brain flatulence here so I had to edit all of my posts. The '67's use the "A" key blank, not the "C" key blank. I couldn't edit my picture so I deleted the post. I will post pictures of the "A" key blanks in this post. They are visibly different but will interchange. Sorry about that.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 09-04-2017 at 09:14 PM. |
#9 | |
Check to see if there is a letter designation on your current key. If your ignition cylinder has been changed in the past it may no longer have the "A" keyway. If it doesn't have the "A" keyway the Octagon key won't work in it. LockDoc
#10 | |
![]() ![]() ![]() ![]() After I posted that picture, I noticed that my key has a 'C' stamped on it. Swapped ignition? The doors are the same key.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#11 | |
Good old American ingenuity.... ![]() "C" would be correct for the '68's. Re-read my posts because I edited them to correct the information. LockDoc
GM used the octagon keys until cars got locking columns and separate ign. & door locks in '68. Trucks didn't get that till '73 but started getting the square keys ahead of that.
