Old 11-15-2014, 01:47 PM   #1
Jimal
Jimal's Avatar
The bed is on, but I've run into a couple technical difficulties...
After a lot of work and a little drama I've got Frankenbed at least sitting on my truck. The problem is, I've run into a couple technical difficulties.
The first I've found discussions on in the forum, which is that the filler for the rear-mounted gas tank comes out directly under one of the crossmembers.
Assuming that the tank wasn't installed backwards by the P.O. and that the filler is supposed to be on the driver's side, what are my work arounds? Can I flip the tank so that the filler is on the passenger side?
The other issue is the front most mount on the frame, or more to the point the lack of said mount.
The weird thing is, I see no evidence of there having been a mount there previous. Is there a piece available for that from the aftermarket, or am I fabricating something?
Jimal is offline   Reply With Quote
