i want to widen rear fenders
i want to add 5 inches to my rear fenders. I've talked to a lot of gentlemen and a lot have said to cut down the middle and add the metal. the guy who will be doing this for me said he would widen from where it attaches to the bed. what are your thoughts on this? would it be better to widen from the center or to where it attaches to the bed?
Re: i want to widen rear fenders
Which fenders? 47-55.1, by the mounting edge or 55.2-59, either way.
http://67-72chevytrucks.com/vboard/s...d.php?t=414646 |
I think he said "by the edge (only)"
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
Widen at the edge due to the curve of the fender. I widened mine 3" and maintained the curve of the fender
![]() Join Date: Jul 2007
Most of the widened fender in progress shots I have seen show the cut to be about 1 to 1-1/2 inch (s) from the lip that bolts to the bed. That gives the metal worker room to work beside the flange but doesn't put the cut out where you have to reshape the filler a lot to have it work.
Back in the 70's before narrowing rear axles was common widening the rear fenders was real common with rear axle swaps. Not always for the better appearance wise though.
widening the fender 5 inches will make it an odd duck
easier and imo better looking is to add tubs inside the bed ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
^ this
and if you can find it, the crew at Kindigit used old fenders to build tubs on one episode of their show, looked really nice when they were done. |
#10 | |
![]() Join Date: Mar 2007
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
PHP Code:
It's hard to upload pics. Here is the backside
Another pic
#15 | |
#16 |
odd duck
![]() widening the fenders looks wrong, imo look at some of the prostreet builds here, there are many nice ones stock fenders and 15 to 18 inch wide tires
#17 |
![]() Join Date: Mar 2011
You asked so here it goes. I don't like the look, I would keep stock fenders, narrow the rear and have tubs inside the bed. Just my 2 cents...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#18 |
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#19 |
polishing a turd
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#20 |
I think it could look good but 5" is probably too much. 2" would probably be plenty and a little more subtle.
#21 |
your opinions are very welcomed thanks, i need to talk to my metal guy, maybe he can do a mock up so i can have a better look, but we'll see.
#22 |
I thuink somebody used to market fibreglas fenders that were already widened 2".
and what a couple said, easier to ask about this stuff before ordering parts that might inconvenient or expensive to alter later. and FWIW, I agree with the others, order your rear axle so the overall length including whatever mega-tires you're going to run fit under the stock fenders, put the tubs inside the bed. |
#23 |
polishing a turd
Get a g50 transmission and mount the engine in the bed. That should piss people off! Lol.
#24 |
#25 |
You can widen them 2" and stretch 'em out a bit to get almost another inch without screwing up the look of the entire fender. Add the strip on the flattest section front to back, use filler sparingly to round it just a bit. Add tubs. I want to use bottoms of real washtubs in my '55, nicely patina'd.
