Old 11-24-2014, 09:26 PM   #1
turbohounds
Aftermarket grill support panel compatibility Chevy/GMC?
I have a 66 GMC and the grill support panel is in rough shape--will the Chevy repop work? Thanks!
turbohounds is offline   Reply With Quote
Old 11-24-2014, 11:23 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Aftermarket grill support panel compatibility Chevy/GMC?
the grille support panel will work, you will have to fill the chevy grille mount holes, and put your own gmc holes. the upper outside holes will be the same.
the inside dual headlight is a little close (the plug) on a gmc grille on a chevy support, however I put a gmc grille on my chevy, and it works fine.
the support itself will bolt on with no mods needed.
60-62 had a different support (no frame notches) , so make sure you get a 63-66.
Old 11-25-2014, 09:24 AM   #3
turbohounds
Thanks! If the ends are the same then worst case I can cut the center sections out of my GMC part and weld them on to the repop.
Old 11-25-2014, 10:09 AM   #4
LT1 Burb
LT1 Burb's Avatar
How much are the repops because I can sell you a good OEM one for 160 shipped and it will fit.
LT1 Burb is offline   Reply With Quote
Old 11-27-2014, 02:40 PM   #5
LT1 Burb
LT1 Burb's Avatar
Heres some pics, as is normal it will need some blocking on the top where the hood closes.
Old 12-14-2014, 03:10 PM   #6
turbohounds
Thanks LT1 Burb - the new grill support looks great. The patina even matches, maybe even too nice
I'm wishing I had found more rust free parts like this, nothing fits like the General.
Old 12-14-2014, 05:21 PM   #7
LT1 Burb
LT1 Burb's Avatar
Hey, it looks and fits great.
gmc, grill support
