Old 12-30-2014, 05:35 PM   #1
forestb
forestb's Avatar
Safe operating temperature
I have a small block 350 in my 62 and was wondering what the safe operating temperature is in stop and go traffic on surface streets.
forestb is offline   Reply With Quote
Old 12-30-2014, 06:01 PM   #2
blown240
blown240's Avatar
Re: Safe operating temperature
Depends on the year of the motor in my opinion. The newer ones seem to be OK running hotter. I had an 86 motor in my 51 that would get up to 215 in traffic and never had an issue.
A little more info on your setup would be nice.
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 12-30-2014, 06:42 PM   #3
forestb
forestb's Avatar
I think it is a 70's motor but I am not sure. It has the dip stick in the drivers side.
Old 12-30-2014, 07:44 PM   #4
donthekawguy
donthekawguy's Avatar
Mine never gets over 185 in the summer in stop and go traffic. 72 350, big cam. I have a shroud and 6 blade fan. I also have a dual electric fan set up but have never had to use it. It should be fine up to 220 or so but you might want to find an open stretch if it gets that high.
66 shorty
donthekawguy is offline   Reply With Quote
Old 12-30-2014, 09:14 PM   #5
LVPhotos
LVPhotos's Avatar
According to your signature, in California so that means you're sitting in traffic for hours on end that would mean you need to be at 210 to 220 degrees. I run a 185 degree thermostat and 210 is max 4 " away from fan, no shroud 400 block. In traffic at light and 100+ degrees.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-31-2014, 01:30 AM   #6
jrobertop88
jrobertop88's Avatar
My block is an 82 350. I was getting past 215°, with a 3k cfm pull fan, on a 3.layer aluminium radiator, decided to flush out the 50/50, completely. And went with mineral water with the royal purple. Just last summer I sat at 180° with the same set up.
jrobertop88 is offline   Reply With Quote
