73-87 gauges
any one have a diagram of what leg of each gauge (Oil / Temp / Gas / Volt) go to? im trying to bypass the printed circuit and wire the gauges direct to the truck harness with a new plug.
Thanks in advance.
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
Re: 73-87 gauges
Looking at the gauges from the back:
![]() Voltmeter (pictured above) Left terminal (marked A) is power Top terminal (marked B) is ground Right terminal (marked C) is a junction between the ceramic resistor and the meter's internal windings (don't make any external connections to this terminal) Bottom terminal is not present I don't have pictures of the other gauges handy at the moment, but viewing them from the same orientation: Temperature Gauge: Left terminal is power Top terminal is ground Right terminal is the sending unit Bottom terminal is a junction between the resistor & meter windings (again, don't make any connection to this terminal) Fuel Gauge and Electric Oil Pressure Gauge both use the same terminal layout: Left terminal is the sending unit Top terminal is not present Right terminal is power Bottom terminal is ground |
#3 | |
Re: 73-87 gauges
Trace the circuit board.
