Old 12-21-2014, 05:54 PM   #1
cardreams
What radiators for ls1 swap
Hey guys what rads should I be using for a ls1 out of a camaro with 4l60 tranny ?in a 70 c10
cardreams is offline   Reply With Quote
Old 12-22-2014, 10:52 AM   #2
Matt Cramer
Re: What radiators for ls1 swap
I just used my stock '72 radiator, using 2005 Silverado hoses. They fit a bit tightly on the radiator side, but putting some dishwashing soap on them let them slide on just fine.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 12-22-2014, 12:39 PM   #3
tbrown5079
Mine is from a 2001 camaro.
tbrown
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
Old 12-22-2014, 03:27 PM   #4
H20cooled
tbrown
Does the 2001 Camaro radiator fit into the stock location. I have heard of people using them but have not found a lot of info on it.
H20cooled is offline   Reply With Quote
Old 12-22-2014, 10:22 PM   #5
crazy longhorn
Fabricate till you "puke"
Same deal here, with dual elect fans....wax on 205/off 195(Painless controls). The old copper /brass rad works, if in good condition? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-23-2014, 08:41 AM   #6
homemade87
Stock radiator works great on my 82 . I see no need to change it out unless you need a new one . Even then I would by a stock one to go back in .
homemade87 is offline   Reply With Quote
Old 12-23-2014, 11:00 AM   #7
yossarian19
I'm using OE tanks & bracket with 4-core high efficiency guts & relocated / resized necks on my '57.
So...
that's totally unrelated to what you are asking.
I think the others are right, though - if you had a V8 truck to begin with, I wouldn't change the radiator. I'd change the hoses to fit the radiator you've got.
Summit Racing has great search features to help you find molded hose with the bends & sizes you need; that and some hose connectors from Speedway Motors and you can plumb anything.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 01-07-2015, 04:09 AM   #8
l92powered77
Red face Re: What radiators for ls1 swap
check out griffin radiators! they are made in south carolina and are custom made to whatever you application is,they make ls swap radiators that have all radiator hoses inlet and outlet on same side.
l92powered77 is offline   Reply With Quote
Old 01-07-2015, 03:19 PM   #9
Wasted Income
Boosted Member
Wasted Income's Avatar
China Champion radiator from ebay and I welded bosses to the tanks for fan mounting. Have to use 4 core mounts, but it works great. Have done it on a couple builds.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 01-07-2015, 03:42 PM   #10
H20cooled
I bought an LS radiator from eBay from seller dissrad, they make them in-house and US made. I called them about a truck LS setup and it is $300. I have heard nothing but good things about their quality and the one I have for my Camaro is very nice.
