Drive shaft question - Bagged SWB 72
Now that my 5.3 and 4L60E are installed, I started to look at measuring for a new drive shaft. My truck is a SWB 72 and it's bagged with cups/plates and Porterbuilt's bolt in notch. It originally had a 2 piece drive shaft and I was going to have a one piece made. However, it seems that it'll hit the upper part of the cross member when lowered. I attached a long 1x1 to the yolk and ran it to the rear end then lowered it and the 1x1 is really close to the upper part of the cross member when laid out. Is anyone else running a similar set up with a one piece drive shaft?
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
meowMEOWmeowMEOW
Re: Drive shaft question - Bagged SWB 72
Other are, but usually with a notch in the crossmember. Are you hitting the cab bottom or the actual trailing arm xmember?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
I have a 6.2 with a 6l80e with a 1 piece drive shaft and mine hits the 4-link and the cab . I will have to modify both
67-72 parts collector,…
![]() Join Date: Nov 2002
Porterbuilt sells a perfect tubular trailing arm crossmember to solve your issue.
Definitely go to the 1-piece driveshaft.
I'm hitting the cross member. Am I OK to trim it a little?
meowMEOWmeowMEOW
If I were the one trimming, I would cut as little as possible and try to reinforce it where I could. Its the point-of connection for your suspension components, so you want it strong.
If I was gonna have an agressive engine combo or race it etc, I'd be way more inclined to go with an aftermarket (or just fab) a new xmember. Just as a thought, you can also get slightly narrower driveshafts built as custom shops if your willing to pay a little. Not sure how much space you're looking to gain.
![]() Join Date: May 2014
Keith you like the one piece driveshafts best.?
I have no opinion on it but it seems to me like the two-piece solves some of the problems when the truck is lowered. And since mine is in good shape and recently rebuilt I could just do a quick shorten when the time comes. Plus I know semi-trucks use two-piece so there shouldn't be a problem with strength. Like I said I have no opinion or experience with this. Just wondering what your thoughts are....
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
I seem to have trouble finding a good oem carrier bearing.
1-piece is just simpler in my mind.
2-piece drive lines on lowered trucks need to have a slip yoke in the rear shaft.
Most 67-72 2wd trucks do not. Except the factory 4-speed trucks.
Thanks for all of the feedback guys. I finally had a chance to really look at things. Seems that I'm hitting the bracket for the center bearing, not the cross member itself. Looks like I can remove it and have plenty of clearance.
Just when I thought I was done drilling/cutting out rivets...
#11 | |
#12 | |
The bottom drive shaft has a slip yoke at the carrier bearig. The driveshaft directly above it does not. Both are found in 67-72 longbed and short bed trucks.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 01-05-2015 at 09:00 AM. |
![]() Join Date: Apr 2005
Keith - it depends on the driveshaft diameter also. I had a 3.5" DS because of the HP in my gold truck with a PB TA crossmember, PB 3" drop trailing arms, and 5" dropped springs. The DS was very, very close to the top of the crossmember. If I had it to do over, I would have modified the PT crossmember OR just went with a 2 piece DS so you don't have to worry about it.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
