Old 01-05-2015, 01:56 PM   #1
PaddyR
Axle Shaft Interchange
I've measured my 1970 rear end between backing plates and have 57". I pulled a shaft and it measures 31 5/16". So I think I'm safe that it has the later 71-72 rear end. Up to what year axle shafts will fit in this to give me 5 lug? Brake shoes are 2" wide if it makes a difference.
PaddyR is offline   Reply With Quote
Old 01-05-2015, 06:41 PM   #2
leftybass209
leftybass209's Avatar
Re: Axle Shaft Interchange
65-69 axles are 30 3/4 inches. 70 axles are 31 1/2 inches.
leftybass209 is offline   Reply With Quote
Old 01-05-2015, 06:54 PM   #3
67c10rustbuket
67c10rustbuket's Avatar
Moser says 1970-1981 chevy truck, 31 5/16"
http://http://www.moserengineering.com/axles/gm-axles/chevy-custom-alloy-axles/1970-1981-chevy-c-10-truck/1970-81-gm-truck-2wd-spline-30.html
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-05-2015, 06:56 PM   #4
PaddyR
I'm measuring from outside of flange to the end of the axle and I'm getting the 31 and 5/16"
Have read on the forum that the 57" backing plate to backing plate is the later 71-72, Lefty am I right here?
If I am can I use a later year c10 axle say up to 81 ?
Old 01-05-2015, 06:59 PM   #5
PaddyR
Thanks Dan you just answered my question so up to 81 axles will work in the wide 1970 for a swap to 5 lug
Old 01-05-2015, 07:22 PM   #6
67c10rustbuket
Yes, I used 72 axles in a 70 housing but any 12 bolt truck axles up to 81 if you're junkyarding.
Dan <---(my name)
Old 01-13-2015, 07:07 PM   #7
Steve-W
Steve-W's Avatar
I'm actually considering the same swap and someone told me you have to also count the amount of splines on the axle (not counted mine yet,,guessing its 30?)
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 01-13-2015, 08:43 PM   #8
PaddyR
Yes my 31 5/16" are 30 spline.
Old 01-15-2015, 08:02 PM   #9
Steve-W
Steve-W's Avatar
Hey Paddy a question for you, if you are changing the shafts..will you also change all bearing and stuff, or leave it as is?
projects:
1969 Chevy C10
1950 GMC 100
Old 01-15-2015, 08:46 PM   #10
PaddyR
Steve, I'm changing the bearings and seals when I swap out the shafts. My truck has been sitting since 90. I'd change the seals for sure when you change the shafts
Old 01-15-2015, 09:23 PM   #11
Steve-W
Steve-W's Avatar
I'll follow your lead ��
projects:
1969 Chevy C10
1950 GMC 100
