Old 10-15-2014, 12:03 AM   #1
Wallee
1972 chevy build/?'s
I just picked up my great uncles 72 chevy c10 lwb after his passing. It was left to me. My uncle bought this truck new in 71. Garage kept and hardly any rust. Runs but could use some tlc. So I'm super happy to have this one owner family heirloom! Now first question, is the stock engine a 350? Small block? I looked tonight but never could find the engine block code as it's covered in grease and it was getting dark.
Wallee is offline   Reply With Quote
Old 10-15-2014, 12:16 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 1972 chevy build/?'s
Pop open the glovebox door, look for a sticker affixed to it. It is called a SPID (service parts id) that will have a lot of info on it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-15-2014, 02:10 AM   #3
dajn
From your discription, it appears to be the original motor. It really doesn't gain you anything. Other than oil stains on your garage floor.
dajn is offline   Reply With Quote
Old 10-15-2014, 08:56 AM   #4
engineer_gregh
engineer_gregh's Avatar
Hi Wallee, I'm sorry to hear about your loss. I'm sure if you post some pictures you'll get a lot of replies from the board about the truck.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 10-15-2014, 09:43 AM   #5
Wallee
I will post up some this evening after work! I just got it last night and didn't have a chance to get any pics yet.
Old 10-15-2014, 03:14 PM   #6
Wallee
Old 10-15-2014, 03:15 PM   #7
Wallee
Old 10-15-2014, 04:12 PM   #8
Wallee
Old 10-15-2014, 04:29 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Looks like a 350
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-15-2014, 04:47 PM   #10
Wallee
That's what the inside of glovebox says as well! I got a leaky intake manifold and exhaust manifold to fix
Old 10-15-2014, 07:17 PM   #11
WIDESIDE72
WIDESIDE72's Avatar
Cool truck. Looks like someone just put a new alternator on it for you!
WIDESIDE72 is offline   Reply With Quote
Old 10-15-2014, 07:30 PM   #12
factorystock
factorystock's Avatar
Looks like a 1970. The original "gold custom cloth" upholstery was actually a "sandy white" color.
factorystock is offline   Reply With Quote
Old 10-16-2014, 10:30 AM   #13
Wallee
Yeah and they didn't hook it up right lol! It's not working. There is 4 wires coming from the alternator that are just hanging loose. Only one wire running to the battery and a plug in is hooked up
Old 10-16-2014, 02:34 PM   #14
1972BlueC20
1972BlueC20's Avatar
Clean up the flat area inside where I circled in red on this picture, there should be a code (example : V1014TRJ) . This will tell you for sure if it's the correct engine for that truck. Not if it's original but if it's correct for that particular truck. If it's correct and the date is prior to the build date of the truck it is also most likely the original engine from the factory.
Get me the code and I will tell you what it means.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 10-16-2014, 02:43 PM   #15
Wallee
1972bluec20 I will do that this evening! Does my truck look like it sits low. Maybe cause of smaller tires? Or is it just me lol
Old 10-16-2014, 04:30 PM   #16
1972BlueC20
The ride height looks about right to me, it may just be the wheels and tires which appear to be correct. Mine is a C20 and sits a little higher in the back, but it doesn't have stock wheels and tires...but they are all the same size all around...I also have heavy duty leaf springs in the rear so that may be why mine sits higher in the back.
Here is mine :
Old 10-16-2014, 04:53 PM   #17
Wallee
1972bluec20 your definitely running bigger tires than I have. Maybe I just need a little more rubber!
Old 10-16-2014, 05:23 PM   #18
1972BlueC20
Yeah they are 265/75 R16
not sure on the wheel size
Old 10-16-2014, 05:29 PM   #19
Wallee
I will check and see what mine are!
Old 10-16-2014, 11:46 PM   #20
Wallee
Block code is VI107tax
Old 10-17-2014, 09:19 AM   #21
1972BlueC20
Ok so here's what we got!
Based on your VIN number :
1970 Chevrolet - 4x2 - V8 Engine - 1/2 Ton - Built in St. Louis, your truck was the 27,142 truck built at that plant in 1970
Based on your engine code :
1970 - 350 engine, conventional cab, Auto Transmission, built at the Flint Michigan plant on Nov, 7th
Check to see if your truck was built in November on or before Nov 7th, if so then this engine is most likely original. There is a blue sticker that is in the door jam on the passenger side that will have a build date.
Hope this helps!!
Old 10-17-2014, 09:26 AM   #22
Wallee
Hope this helps!!
Man your awesome! Helps a ton! Lol idk why I thought it was a 72!
Old 10-17-2014, 10:10 AM   #23
1972BlueC20
Cool deal, glad I could help!
Take care!
Old 10-17-2014, 10:45 AM   #24
Wallee
Thanks! Getting up in the morning and installing some gaskets and fixing that alternator. Got to find where all the wires go. Might snap a pic and see what you guys think.
Old 10-17-2014, 06:33 PM   #25
Wallee
Truck was built on 11/69
