Old 01-16-2015, 11:33 AM   #1
mgkgmc
mgkgmc's Avatar
Pinion Shaft lock bolt broken
I am in the process of switching my axles out on my 12 bolt rearend and when I attempted to remove the Pinion shaft lock bolt it was broken in half. So from what I hear its pretty common to have this happen. So my question is there any tips or tricks you guys may have done to make this as painless as possible to remove it.
1970 GMC 1500 stepside
1972 GMC Jimmy Custom
2004 Chevy Colorado
1989 Swb Silverado
1972 Aj's Stormer
mgkgmc is offline   Reply With Quote
Old 01-16-2015, 05:35 PM   #2
john
member #16
john's Avatar
Re: Pinion Shaft lock bolt broken
There is an extractor kit to remove the broken bolt.
http://www.fabbriassociates.com/kitinfo.html
john is offline   Reply With Quote
Old 01-16-2015, 06:17 PM   #3
Mike C
Mike C's Avatar
That's a cool kit, file away for future reference.
Sometimes you can use a magnet to pull the broken part of the pin out. If you can find a long, skinny, powerful one! You can put your hand around the case, middle finger on backside of spider gear shaft and thumb on top and rock the shaft as you are trying to magnetize it out.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-16-2015, 06:54 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
The extractors work great. I fought mine for 3 days, ordered the kit and had it out 15 minutes after I received the extractor kit. You can get them at Amazon too.
LockDoc
Leon
Old 01-16-2015, 07:16 PM   #5
ssxty8
Thumbs up Re: Pinion Shaft lock bolt broken
Hope the kit works for you. Appart from that, a left hand drill bit comes to mind. Been there done that.
Good luck.
ssxty8 is offline   Reply With Quote
Old 01-17-2015, 02:14 AM   #6
mechanicalman
Before you do anything, spray WD40 on it, blow it with compressed air, repeat a couple times (blow the WD40 into the threads) then try to walk it out with an O ring pick. I've extracted many that way, but it depends on if it's beaten up or not.
mechanicalman is offline   Reply With Quote
