Old 08-31-2019, 01:49 PM   #1
LagunaGlide
18 in Steel Wheels?
I am curious if there is a cheap(er) option for 18in steel wheels that will fit the 6lug trucks. I am planning to do a brake conversion, but am not ready to spend coin on expensive wheels. Would prefer to just get some cheapo steel wheels for now. Any suggestions on what fits?
LagunaGlide is offline   Reply With Quote
Old 08-31-2019, 02:03 PM   #2
KMC3420
KMC3420's Avatar
Re: 18 in Steel Wheels?
Not sure exactly what your looking for but you can check mobsteel and wheelvintiques. They both have 6 lug options and typically in the 18” sizes. Cheap(er) is a relative term, good luck in your search.
Mobsteel
Wheelvintiques
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 08-31-2019, 04:38 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: 18 in Steel Wheels?
Are you going with a bigger front brake kit? If your just going to a normal disc kit you can run the rally wheels in 15". They look good and you can find them cheap on craigslist in most area's.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-31-2019, 06:55 PM   #4
aerotest
https://www.uswheel.com/wheel/11996/...65/?finishID=9
17” & 20”...no 18”
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 09-01-2019, 09:54 AM   #5
LagunaGlide
I was hoping for maybe some factory takeoffs off any other vehicles that may work temporarily. The truck won't be driving much for awhile, and I won't be ready to measure and choose a style of wheels for some time.
