Moderator
![]() Join Date: Jul 2006
GM 4 speed O/D to 5.3L
![]() The plan is to mate this to a 5.3L for my '50 chevy. I want a manual trans but don't really want to deal with 1) high price 2) hydraulic clutch or 3) 1:1 final drive. This trans should solve all of these problems while being different. The gearing is close to 700R4 at: 3.09:1, 1.67:1, 1:1, 0.73:1 Now just to figure out how to properly mate it to the 5.3L...
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
Hollister Road Co.
Re: GM 4 speed O/D to 5.3L
The cranks are different on 5.3 auto and manual. You may need to get a 5.3 that was manual to make it work or get a flywheel adaptor.
Moderator
Well after talking with Novak, it should be the same as any other Gen1 4 speed to LSx. Use the old bellhousing, 4.8L flywheel and clutch and a conversion pilot (.400 longer?) bushing from Novak. I'm not sure about the clutch linkage though.
Moderator
Not sure if anybody is watching this thread, but surely someday somewhere somebody will want to put a GEN I manual transmission behind a GEN III engine. Well, after literally weeks of searching I found this, the holy grail. For about $80 and a trip to O'Reillys I'll be in business:
http://pirate4x4.com/forum/showthrea...1#post11161311
just happened to be readying an old CHP mag and found someone asking the same question they gave a part# for just your problem it's an ls crank spacer #12563532 this makes up the 0.004 inch on the crank the longer bolts are #12553332 this is a cheap way to do it if you don't want to buy the new flywheel. hope this helps
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#6 | |
Moderator
I realize this is a old thread but was wondering if you got that trans mated and what you had to do. Im about to do the same swap
Good info for my next build with a L S
![]() Join Date: Aug 2012
If i can't find a nv3500 to stick behind a 5.3, i'm looking to do the same. In my research, i found these articles from carcraft and hottod mags to be very helpful.
http://www.hotrod.com/how-to/transmi...on-swap-gen-3/ & http://www.hotrod.com/how-to/engine/...s-style-block/ |
