1970 Cab for Patches
Here's a non AC cab that I'm selling patch panels from. The floor, rocker, kick panel areas are bad, but the rest looks to be in good shape. Patches start at $25 plus shipping. The entire dash cut at the windshield is $75 plus shipping. Let me know what you need!
Thanks, Ray |
Re: 1970 Cab for Patches
pics
Can you cut me the passenger side cab corner please? Can you please cut it similar to how this pic is please. If there is anyway to get it apart without removing the spot welds where the rear floor is attached to the cab corner and leave just the area of metal that's attached to the cab corner intact I'd appreciate. If there is a way to remove it by drilling out the spot welds cleanly that would work to but not necessary.
Scott Last edited by sduckworth13; 02-07-2015 at 11:25 PM. |
Yes. $25 plus shipping. I will cut and verify that it is good and solid.
Thanks, Ray |
Thanks Ray.
Scott |
![]() Join Date: Jan 2012
Can you cut drivers side windshield lip off I need from the door post over 24 inchs
passenger Side roof panel? About 20 inches from drip rail from windsheid to rear window. How much you think shippng?
I see their is a wiring harness in their still, how bad is it?
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
I would like to get a 8" x 8" square cut out of the front drivers side roof and 6" down the front post.
So go over towards the center of the cab from the corner of the windshield 8", then 8" towards the rear of the cab from the upper front door frame corner . The down the windshield post about 6 or 7" Thanks, Wade
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
![]() Join Date: Oct 2013
How much for the gas pedal if the stud holes are not cracked. To Nashville. 37027
Active Member
![]() Join Date: Dec 2004
Ray, I'm looking for this cowl piece in no rust condition, mine is rusted low on the inside of cab. Shipping would be to zip 08015 NJ Thanks
#15 |
Here is the section I need hope this helps. About about 16 inches from drip rail . In need of the upper door jam part also that the roof tack welds to where the drip rail also welds to.. thank you so much.. and shipping would be to zip 73010
#16 |
This is the section I was refering to in post #12
Shipping to 70769 Thanks, Wade
#17 | |
#18 |
#19 |
$50 plus shipping for this section. I won't know if it is rust free until after I cut it. I can't get exact shipping cost until I know the weight, but I will send out fedex ground when possible.
#20 |
$50 plus shipping for this section. I will cut the a pillar at the top, then I will start at the b pillar and cut it fat behind the seam, I will then cut parallel 17" from the passenger drip rail. so you will get all of the drip rail and some windshield lip that you can pare down to your needs. I will ship fedex ground and have cost when cut.
#21 |
A rare storm is coming through here so I will be making the cuts on Tuesday when it clears up.
Thanks for your patience! Ray |
#22 |
10-4 .. I will hold off a couple days because I will be leaving town for work. I will contact you and let you know when I will need it
. Thanks |
#23 |
this is what i need
#24 |
I'll take the pedal. Just please confirm that it mounts to two floor mounted studs and that the stud wells are not cracked. If ok please send parent info in pm
#25 |
I made some cuts today. The cab corner is bad. The windshield lip was sacrificed to save the uncut dash, but I might be able to get it from another cab. The gas pedal is cracked. I will see if I have a good one. The wiring has many splices. I will get the 8x8 section tomorrow.
Thanks, Ray |
