Old 02-14-2015, 08:12 AM   #1
Paul Y
Real Newbie question regarding the removal of A Arm bushing...
Gentlemen
Whilst not new to Cars, i am new to the particular 'nuance' of the 66 C10.
I see that the A Arms do not employ a bush in the traditional sense. I need to remove the 'pivot arms' (best description I could come up with). What is the best ay to go about this?
Do I need any special tools?
As they are out is there anything I should be looking for or do with them?
P.
Paul Y is offline   Reply With Quote
Old 02-14-2015, 12:30 PM   #2
SCOTI
SCOTI's Avatar
Re: Real Newbie question regarding the removal of A Arm bushing...
Originally Posted by Paul Y View Post
Gentlemen
P.
On the 63-72's the a-arm bushings are threaded metal sleeves w/rubber seals. They really don't wear unless subjected to extreme abuse or poor installation (loose/over tightened). The end caps are just big threaded nuts. They can be removed w/a socket (if you have one large enough) or the more common blue collar approach w/a large adjustable cresent or pipe wrench after being secured in a vise.
Inspect them. If they don't appear in bad shape, clean them up & re-use them if the seals look good. When you re-assemble, thread each side onto the a-arm shaft as evenly as possible. Snug them gently (no torque). Once the truck is on the ground w/the suspension loaded, then do your final tightening. This keeps the bushings from being pre-loaded.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
