64 drop spindle cross member swap ?
Thank you guys for all the info on here. I'm getting everything ready to start my 64 c10. Starting with suspension and i have a few questions (which I'm sure will turn into many more), I am doing a 77 cross member swap. i have a rearend from a 88 camaro with disc brakes and 3:73 posi. I am going to bag it so my question, is there a drop spindle/rotor that I can use to get a 5 on 4.75 bolt pattern to match the rear? Like does a 77 camaro rotor fit a 77 c10 spindle? any other ideas on the best/cheap way to get a nice set up on the front end. Thank you for taking the time to help.
Re: 64 drop spindle cross member swap ?
The company that you order the spindles from should sell that rotor. I would assume CPP sells them.
60-66 Nut
Thank you guy s so much. Best forum that I have seen. I will post pics as I go. I'm sure I will have many more questions along the way but I'm hoping this project I ask the question rather than make the mistake.
