Rollin' Old Skool
manual vs. power front disc brakes
so, i'm getting closer to a front end rebuild on my '66...i will be converting to front disc brakes during the process...i'm just wondering if i should convert to a power booster/master cylinder for disc or just change to a manual master cylinder for disc...how much of a difference will i notice? it will still have rear drum brakes...and i actually have a '72 parts truck with booster, but i'm not sure if the booster is good....also just for reference, the truck is a 1/2 ton short/fleet with 327/auto...when finished, my plan is to drive it 2-3 times per week
thanks for any info/help/suggestions |
Re: manual vs. power front disc brakes
you've got the parts...might as well.
Grandpa in the rustmobile...
power is easier, non power looks cleaner on the firewall..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
But Found Her 25yrs Later!
I think he said he wasn't sure the booster was any good.
I think he's asking if he'd be fine with discs up front, but no power.
Hell yeah!!!
I used a ' 72 corvette manual disc brake master with proportioning valve out of my donor '73 c10 and it stops surprisingly well. Have not had any problems.
Stock is good but custom is the sh*t! |
#6 | |
Rollin' Old Skool
thanks for the info |
oooooh....well yeah in that case you'll be fine w/o the booster.
Though depending on how your WOAH:GO!! ratio you may want the power brakes. |
If you go full manual, raise your brake pedal rod on the arm if possible, it will give you more pedal force.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Senior Enthusiast
After I swapped in the 75 front suspension with disc brakes I ran a manual master cylinder for a year or so. I have missing spinal discs, and over time it got to where I could barely stop the truck it hurt so bad to apply the amount of pressure required with the manual discs up front. I decided it was time for a booster. Once that was in place I've never a problem since. So from the experience of someone with chronic back pain it makes a huge difference having the booster, and I have a somewhat small booster - the 9" single diaphram type from Master Power Brakes. A bigger booster would probably reduce pedal effort even further:
http://www.mpbrakes.com/uploads/prod...1753_large.jpg |
My kid brother and I converted his '64 GTO from drum front to 4 piston Vette caliper disc and those brakes would put you through the window. Of course that could have been because the lawn chairs we were sitting in weren't bolted down yet! Seriously though manual disc did not seem to require more force than manual drums but it stopped WAY better. I remember when he put the booster in and it seemed real touchy to me for a long time. Still stops great and that was done 25 years ago.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
![]() Join Date: May 2007
I think Mark hit it right. If you are good and healthy then you will have no problem with manual disc brakes.Power brakes simply make it easier.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#12 | |
great idea btw ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
The other thing to keep in mind is the amount of vacuum your engine will make. If you are running a rowdy cam it may not have enough vacuum to actuate the booster.
Just remember the booster doesn't make the brakes function any differently inregards to stopping distance, it only reduces the amount of pedal pressure you have to apply. The guy that runs this shop is the guru when it comes to braking... and he answers emails too! Click on this link: CH Topping & Co., Performance Brakes He helped me with the set-up I have on my Ford 1927 Roadster Pickup. It has a manual disc/drum set-up and also uses a 'vette disc / disc master cylinder, like Nachodog referenced above. Last edited by lakeroadster; 04-26-2011 at 07:45 PM. |
Good Stuff....I'm going with the manual one from CPP for $139 with the valve.
#15 |
Well post some pics of before and after and maybe a little wright up about it.
#16 |
![]() Join Date: Nov 2009
[quote=lakeroadster;4648030]The other thing to keep in mind is the amount of vacuum your engine will make. If you are running a rowdy cam it may not have enough vacuum to actuate the booster.quote]
Yes, Lake is correct. I am running a big mutha thumpr cam in my truck and as a result i HAVE TO run manual brakes. It is my understanding that you need at least 14-15 lbs of vacum to run P/B's as designed. With my cam, my engine is putting out about 2-3 lbs. I don't see any problems running manual over power. Last edited by CVA59; 04-29-2011 at 10:28 AM. |
#17 |
This is great to know! I am a less parts less systems kind of guy...
#18 |
![]() Join Date: Oct 2009
CVA 59 - 2-3 lbs!! You MUST post an audio clip of that cam... sounds like a mighty loper. Gotta love that sound!
#19 |
LOL, I will get a vid up for sure. I hope to have it running in 3-4 weeks.
#20 | |
[quote=CVA59;4652880]
#21 |
I'm still fighting power discs on my 66.
I'm going to go get a vett master and see if I can get solid brakes that way.
#22 |
![]() Join Date: Jun 2014
Anyone know what the bore size is on the vett master?
#23 |
67 and up power assist used a 1 1/8 bore and the non power models were a 1" bore.
GOD BLESS AMERICA! |
#24 |
Well been driving with manual brakes for a while now and no problems at all. No need for all those power parts. IMO
#25 |
Kids in the back seat may cause accidents, accidents in the back seat may cause kids, so no back seats no accidents.
EPIC! LOL |
