Old 11-02-2014, 04:14 PM   #1
min
min's Avatar
1967 swb/stepside daily driver
Have wanted to build a 67 small window, swb, stepside for the last 15 years or so. After looking for the last couple years, I found a good deal on a truck that was a basket case.
This is going to be my daily driver when finished. Have been working on the truck and collecting parts for a little over a year now.
I know everyone loves pics.
Here is the truck getting picked up
min is offline   Reply With Quote
Old 11-02-2014, 04:26 PM   #2
min
min's Avatar
Re: 1967 swb/stepside daily driver
Stripped it down to the frame. The frame was in real good shape with just a little surface rust.
Old 11-02-2014, 04:35 PM   #3
min
min's Avatar
striped it down and sand blasted everything. used the harbor freight 110# sand blaster...you can see it in the pics.
Old 11-02-2014, 04:41 PM   #4
min
min's Avatar
painted everything with Eastwoods epoxy primer and 2k ceramic chassis black.
Old 11-02-2014, 04:59 PM   #5
min
min's Avatar
for the rear suspension i went with the ece 6" drop springs, shock relocaters and there super track bar. also put new polly bushings in the track bars.
Old 11-02-2014, 05:23 PM   #6
min
min's Avatar
rebuilt the front suspension with all new moog ball joints, a-arm bushings and tie tod ends inner and outer. converted to front to disc brakes with the ece 2 1/2" drop spindles and 1 1/2" drop springs.
suspension all done with the ece 4/6 drop. 15x8 wheel vintiques corvette rally wheels with 275/60-15 all around.
Old 11-02-2014, 05:29 PM   #7
'68 Newtricks
'68 Newtricks's Avatar
nice start!
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 11-16-2014, 10:41 PM   #8
min
min's Avatar
for the engine and tranny i wanted to use the 250 and a 5 speed from an s10. got the engine running to make sure everything was ok...started right up and sounded good after sitting for 10 years in a field and the last 10 years in a garage. after taking it apart to change all the gaskets i found out there was alot of rust inside the engine. the oil had the rust all through it and after running it for a good bit it was all through the engine. i am on a low budget and can not afford to get it rebuilt so i went in a different direction.
had a 305 from a 91 camaro and 700r4 from another project setting in the garage so i decided to just use it. striped all the fuel injection and emission crap off and repainted it and changed over to a carb.
Old 11-16-2014, 11:10 PM   #9
min
min's Avatar
installed the engine and tranny and got the exhaust made. used hedman shorty headers and 2.5in pipe to summit race mufflers. tried to keep the exhaust as close to the frame as i could.
Old 11-16-2014, 11:18 PM   #10
nds1968
nds1968's Avatar
Looking good! keep at it
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 11-16-2014, 11:26 PM   #11
min
min's Avatar
Originally Posted by '68 Newtricks View Post
nice start!
thanks.
Old 06-15-2015, 05:06 PM   #12
min
min's Avatar
It's been a wile since i updated this build. The cab that came on the truck was shot. The roof was rusted through on the inside and outside. Found another cab in a lot better shape. It was sand blasted and in primer but the sandblasting worped some of the sheet medal. Just some more body work.
Old 06-15-2015, 05:20 PM   #13
min
min's Avatar
one of the rear cab braces was missing so welded in a replacement and sprayed the underside with Raptor bed liner.
Old 06-15-2015, 05:37 PM   #14
papapericos
nice truck!
papapericos is offline   Reply With Quote
Old 06-15-2015, 05:39 PM   #15
min
min's Avatar
A good friend of mine has a collision repair shop and offered to heip me paint it. After getting the cab and doors ready for paint i now understand why it cost's so much to get something painted. It was alot of block sanding to get this body straight again.
Old 06-15-2015, 05:46 PM   #16
min
min's Avatar
Sprayed the Raptor bed liner on the inside of the floor and under the dash to help seal from leakes.
Old 06-15-2015, 05:51 PM   #17
min
min's Avatar
Went with Tanger orange in base coat clear coat.
Old 06-15-2015, 06:05 PM   #18
min
min's Avatar
Mounted cab to the frame and put the doors back on and got to bring it home. It is starting to look like a truck again.
Old 06-15-2015, 06:14 PM   #19
min
min's Avatar
Tinted the rear window with 2.5% limo tint.
Old 06-15-2015, 06:33 PM   #20
min
min's Avatar
While the front end is off now is the time to finish up the engine compartment. Restored the heater box and put in a new heater core, radiator, hoses, trans cooler.
Old 06-15-2015, 06:43 PM   #21
min
min's Avatar
The truck had a 250 six in it so the stock manual linkage was to short. Got 2 rod ends and some allthread and made a new one.
Old 06-15-2015, 07:02 PM   #22
68panelman
68panelman's Avatar
Very nice, At the rate your going , you'll be able to drive that to Truck Carlisle.
68panelman is offline   Reply With Quote
Old 06-16-2015, 08:52 AM   #23
68Gold/white
Look'n Good, Billy Ray!!!
68Gold/white is offline   Reply With Quote
Old 06-16-2015, 03:11 PM   #24
chopnchaneled
chopnchaneled's Avatar
I would be scared to drive a truck thats as nice as what your doing
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 06-16-2015, 03:32 PM   #25
Lokin4AReason
Lokin4AReason's Avatar
really nice progress on the truck ..
keep up the good work =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
