Rear disc brake chatter/squall
What causes the rear disc brakes to chatter/squall. It does it when there is light pressure on the brakes. I'm a pretty casual driver and don't stop within the last 10 feet of a stop sign. So when I apply the brakes the reach a certain pressure and it sounds like a wallraces getting it on. As I apply more pressure it goes away. If I apply the brakes for slowing down it does the chatter/squall when I apply and release the brakes. I've tried different pads and and I cleaned and cleaned the rotors. It seems to mainly do it at 30mph and below. Seems as if theres enough residual pressure after releasing the brake pedal that 5mph below I can hear a faint chatter squall. The setup I have is a 12 bolt in the rear of my Suburban with The Right Stuff rear disc conversion with Cadillac calipers. I don't have the parking brake cables hooked up yet. The rotors are new of course. I'm not sure what to do or where to start outside of new pads which I've already done. Should I turn the rotors for some reason? The machining marks are about worn off. I thought maybe it was from that. I've never had this issue before.
Re: Rear disc brake chatter/squall
One thing you can try..(I do this with all my pads front and rear) bevel the pads edges all the way around this will help with noise and chatter.
good luck.. Mark...
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
I think you have answered your own question. ( I do not have the emergency/park brake hooked up ) . Those calipers have to have the park brake hooked up and use it quite frequently for those calipers to work. That is what adjusts them to compensate for the wear . If not used the pads will wear down and not make firm contact which is what is most likely causing your chatter at light peddle apply. Also most likely your not getting the braking power to those rear disc like you should . Get the cable hooked up and I think your problem will be fixed.
The right stuff has install instruction but I think there is better instructions out there for these calipers in better detail . Here a mp brake instruction on the emer/brake lever install. http://www.mpbrakes.com/docs/orig-gu...STRUCTIONS.pdf Last edited by homemade87; 11-22-2014 at 08:45 AM. |
I'm at a loss. I tried a couple different brands of pads again with no luck. Tried semi metallic and ceramic pads. Best luck is with Duralast ceramic pads. I beveled every set of pads. As I said the Duralast yielded the best results before parking brake cables I put parking brake cables on. Adjusted them as the instructions said. I set the parking brake everytime I got out. It's now worse then ever. I can sometimes hear it faintly at 40+mph. It's loud enough at slower speeds that people stop what they are doing to look to see where the noise is coming from.
#6 | |
It also could be your rubber hose above the rear-end has collapsed and not letting enough fluid past to apply the brakes properly . This would also keep a decent peddle feel . Did you have trouble bleeding the rears . I cant stress enough about the parking brake being properly adjusted . If you are confident that it is I would look into the things above . Something else that comes to mind is if the mounting bracket is properly spaced so the caliper is center so the pads have an even travel to the disc . |
All of the flexible hoses are new throughout the brake system. The pedal is tight as it should be. It stops great. It was at a point that it squalled with light pressure to now it does it as if there's always slight pressure because its squalling with my foot off the brake. I'm about 75% sure the pistons are adjusted correctly. It was good when I first adjusted them The more ive set and released the parking brake the worse it has gotten. The brackets was one of my initial thoughts. Since the caliper can only slide outward so far I thought maybe the outer (closest to the wheel) pad was causing the issue. There is a small gap between the caliper and bracket. Maybe 2mm at most. That should be plenty I would think so the caliper could float as needed with endplay of the axle shaft.
I think you have a caliper sticking. You shouldn't be hearing any brake noise at 40 mph. How old are these calipers? I have rear discs on a couple of my Caddys and I never ever use the E brake. I have always had very good brakes with no noises. I have had to replace my calipers twice in 15 years because the E brake adjustment gets frozen up from non use and I'm too lazy (or in a hurry) to take them apart and fix them. If there were noises associated with not using the E brake I would have heard them by now. I think you just have a sticking/defective caliper.
I am trying to use the E brake more often now since that's the way they designed it. Thankfully Caddys have automatic E brake release so it isn't that much of a hassle.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Run to the shop and get the high temp silicone, put a bead on the caliper cup where the brake pad back meets it. The sound that you are hearing is the harmonics of the cup. Its like a wet finger on the crystal glass, makes a tone. The silicone will act as a vibration dampener.
84 K30 CC LB Fleet side 454/400/205/14 bolt Rebuilt 2200 miles 91 K15 Z71 SB 350/700r/241c/12 bolt 372k miles 96 K15 Sub 350/4L60/243c/10 bolt 333k miles |
#10 | ||
