Old 03-27-2014, 07:27 AM   #1
Matty Wagz
Matty Wagz's Avatar
700R4 install question??? about electric plug
Hello All, just got a low mileage; clean; GM Goodwrench 700R4 trans... i understand what i need to do as far as driveshaft shortenend, change/ move cross member, etc;
I wanted to ask all the Gurus what i needed to do with the 4 wire plug here on the driver's side of the trans? I have heard that you need to loop out certain pins here/etc to keep it from locking up??
Also, am i correct in just thinking I can get an electronic speedometer to connect to the sending unit on the trans?
thanks in advance,
WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC
Matty Wagz is offline   Reply With Quote
