Old 02-26-2015, 03:50 PM   #1
jabos
steering column on my 69 nontilt
hey guys i pulled my steering wheel off to replace it because it was all cracked and falling apart and something came loose in the shaft on the engine side and am not sure what it was, any ideas of what it could be? I am waiting for my new steering wheel from classic chevy and hoping i didnt screw something up in the shaft
jabos is offline   Reply With Quote
Old 02-26-2015, 04:23 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: steering column on my 69 nontilt
Not much you can screw up by taking the wheel off. Did the shaft drop down? What makes you think something came loose? The lower bearing may be bad.
LockDoc
Leon
Old 02-26-2015, 05:43 PM   #3
jabos
seems like i have more back and forth motion now on the steering wheel shaft
Old 02-26-2015, 05:47 PM   #4
jabos
is there a way to tighten that up
Old 02-26-2015, 06:17 PM   #5
john
member #16
john's Avatar
That slack should tighten up when you put a wheel back on.
john is offline   Reply With Quote
Old 02-26-2015, 06:59 PM   #6
jabos
I did put the new wheel on and there is some slack back and forth about a 1/2 to 3/4 of an inch. is that normal?
Old 02-26-2015, 07:38 PM   #7
LockDoc
LockDoc's Avatar
It shouldn't feel any different than it did with the old wheel. Changing steering wheels doesn't change anything in the column....
LockDoc
Leon
Old 02-26-2015, 07:46 PM   #8
Mike C
Mike C's Avatar
Sounds like one of the bearings was worn and the lower may have slipped from the bottom and the balls fell out of the bearing cage? That's all I can think of. The column should be tight with the wheel on or off.
Just to verify, the play you have is up and down/left and right versus in and out correct?
I know on my Jimmy the upper bearing was missing a ball or two and the cage was damaged, but that put no slop in the system.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-26-2015, 07:55 PM   #9
jabos
The play in the steering column is in and out
Old 02-26-2015, 08:12 PM   #10
Mike C
Mike C's Avatar
I think that is set by the lower bearing. Never had to actually work on that part of the column. Find any steel balls in the driveway after this job?
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-26-2015, 08:23 PM   #11
jabos
No, I didnt notice any.
Old 02-26-2015, 08:24 PM   #12
LockDoc
LockDoc's Avatar
Look at your steering column under the hood and compare it to the picture posted below.
LockDoc
Leon
Old 02-26-2015, 08:47 PM   #13
jabos
how do you attach pictures
Old 02-26-2015, 09:12 PM   #14
jabos
[attach]1369766[/attName:  image.jpg
Old 02-26-2015, 10:42 PM   #15
LockDoc
LockDoc's Avatar
[attach]1369766[/attAttachment 1369766ach]
Your bottom bearing and coil spring are gone.... All you have left is the large washer.
LockDoc
Leon
Old 02-27-2015, 07:28 AM   #16
jabos
Thanks for all your help, I guess I need to figure out how to replace that.
Old 02-27-2015, 08:04 AM   #17
jabos
do you know where i coulc find those parts?
Old 02-27-2015, 10:49 AM   #18
LockDoc
LockDoc's Avatar
Any '67-'72 parts vendor should carry a lower steering column bearing repair kit for that. It will have everything you need in the kit. It should run about $35.
LockDoc
Leon
Old 02-27-2015, 03:50 PM   #19
jabos
Does the steering shaft come apart right there?
Old 02-27-2015, 04:55 PM   #20
LockDoc
LockDoc's Avatar
Yes, you have to remove the bolt there and take the rag joint apart at the steering box and it will slide apart. It looks a little rusty so I would spray everything with a good penetrating oil (not WD-40) and tap it with a small hammer to loosen it up.
Here is a thread you might find helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=471499
LockDoc
Leon
Old 02-27-2015, 06:04 PM   #21
jabos
hey i want to thank you for all you info, i am going to order that bearing and give it a try. do you think it is ok to drive until i install it?
Old 02-27-2015, 11:34 PM   #22
LockDoc
LockDoc's Avatar
Sorry, not going to answer that one. That will be your call... No problem on the help. Let us know how it goes.
LockDoc
Leon
