Coolant temp sender idea
Hi all, I have been trying to figure a way to install my factory temp sender for the dash in my '76 with out being to intrusive. I tried to turn down a sender and cut threads into it and the sender was to thin. I don't want to drill and tap the head or the water pump, but I remembered that some ford products had a temp sender/switch in the heater hose like this one pictured. I figured I could cut the tube, flare the end and install it in line. Anyone have pro/con's about going this way?
Thanks, Matt
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 Last edited by mattcrp1; 02-14-2015 at 11:31 AM. |
The Older Generation
Re: Coolant temp sender idea
I think you would have to make sure the resistance of the sender matches the gauge...... Not sure on the newer stuff. LockDoc
I was planning on installing the factory '76 sender and adding a ground to the sender as it would be insulated by the rubber. Do you think it would be accurate enough in relation to engine temp if I mounted it on the heater outlet side of the engine?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
#4 | |
I don't have a clue on that. I think I would want it in the head. I drilled and tapped the head on mine to 1/2" NPT so I could use the stock '67-'72 gauge style sender. LockDoc
It will read differently in the head. Heck, I have the factory one in the drivers head (front of cyl #1) and it reads different than the autometer one installed in the passenger head (behind #8). At first I thought the gauge was off until I pulled the sender and hooked it up in a pot of water. Verified it was correct.
My buddy with a 67 LS1 has his set up the same way I do. He sees the same issue. About 10% difference for both of us. IE the passenger rear is 10% hotter than the drivers front.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
#6 | |
I have read that having it at #8 will give you the most accurate reading of the actual engine temp. LockDoc
That's why it is hooked to my gauge not the computer. I can look at it on the track.
#8 | |
After trying to cut down a stock sender ( the one on the right) to put in the rear position in the passenger head, I got a couple of brass pieces to put it in line with the outlet to the heater core.
I added a ground wire to the brass "T". I figured as long as it can give me an indication of where I am temp wise it should be close enough.
What pieces are inside the stock sender. I think I lost one when I turned it down, all I have is the spring.
#12 | |
It's alsways something.....
![]() Join Date: Nov 2008
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Made a sleeve for mine in the top radiator hose and ran a ground wire. One side has the temp sender, the other side the fan sensor.
tbrown
tbrown's 56 Cameo Build |
Well I got it mounted in line and filled the cooling system. I forgot to fill the upper hose when I lit it off and ran it for a minute. I realized that the hose was not getting warm and shut it off and filled the hose. The hose got warm immediately and seem to be working fine so far.
