Old 03-05-2015, 03:25 PM   #1
vancelot69
vancelot69's Avatar
Dead Battery?
Anyone have any ideas about this?
I got a new battery from O'Reilly's last May. Since then, my Jimmy has sat more than it's been driven (220 days had, 50 days driven before Dec 8), but up until this last weekend, it had started fine every time.
The last time I drove it more than just a couple of miles was Dec 8, 2014. Since then, I have only driven it a handful of times, for about 13 miles. Those dates are: 4 days later on Dec 12, then 9 days later on Dec 21, then 34 days later on Jan 24, 2015. Then, this past weekend, on Mar 2, 37 days since the last time, the battery was completely dead, it wouldn't even budge the voltmeter. I jump started it with my wife's MDX, then let it run for several minutes and drove it about 3 miles to try to keep it "up". Then I went to drive it again today because it snowed last night and I wanted to get out and play, and the battery was completely dead again. It wouldn't even budge the voltmeter again. So I jump started it again with my little Jimmy, ran it for several minutes, then drove around the block a bit and to AutoZone and had the guy check the battery and he said it had 12.03 volts, but was only at about 23% charge.
So, could my problem just be that it's been sitting for so long without being run for any real length of time? Or do I have a bad battery? Or do I have a drain somewhere, and if I do, how would I track that down? I've always thought it sucked trying to track down electrical issues
Thanks in advance for any help y'all can give.
My toys:
1971 GMC Jimmy
2008 Hummer H3 Adventure
2003 HD Road King
vancelot69 is offline   Reply With Quote
Old 03-05-2015, 06:56 PM   #2
BIG ORANGE
BIG ORANGE's Avatar
Re: Dead Battery?
Sounds like a bad battery, might even have a alternator that's not charging. A bad alternator and kill a good battery, and speaking of thanks in Advance,
well I work for Advance Auto Parts, stop by and let them test yr battery and Alt. its free and they carry great batteries and life time warranty Alt...
Don't forget to check the voltage regulator to,
just saying,,
Donnie
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 03-05-2015, 07:59 PM   #3
pound41
Re: Dead Battery?
i had similar issue it was a short in the column for the horn.
pound41 is offline   Reply With Quote
Old 03-05-2015, 08:18 PM   #4
grillzy
Re: Dead Battery?
Could be bad diode in alt. It will back draw
grillzy is offline   Reply With Quote
Old 03-06-2015, 08:20 PM   #5
thightower
Re: Dead Battery?
Hey pound 41, where exactly was your short, went to start mine today and the battery was dead, I had my steering column apart last weekend to fix my horn. Guess I need to take it apart again!
thightower is offline   Reply With Quote
Old 03-07-2015, 01:44 AM   #6
Ewr101
Ewr101's Avatar
Re: Dead Battery?
You should buy a Battery Tender. I love mine. I've only been able to drive mine a handful of times since November but it cranks up every time, no problem. Just a suggestion.
72 Chevy 2WD Blazer
Ewr101 is offline   Reply With Quote
Old 03-08-2015, 02:16 AM   #7
vancelot69
vancelot69's Avatar
Re: Dead Battery?
Yeah, I might have to get a tender.
Friday morning I went out to start it, and it churned about a half turn before stopping, so I jump started it again and drove to work. After lunch, I went out and it started fine, then drove home that afternoon. Saturday evening it started right up. So, it probably is "just" that I let it sit for too long without putting any real time on it. :\
Thanks again!
My toys:
1971 GMC Jimmy
2003 HD Road King
Old 03-08-2015, 10:50 AM   #8
thightower
Re: Dead Battery?
you can always unhook your positive cable and then put a meter between it and the post, it will tell you if you have a drain or not.
Old 03-08-2015, 08:08 PM   #9
2003 silverado
2003 silverado's Avatar
Re: Dead Battery?
you can use a 12 volt Light bulb tester an go in between the fuse holder to find what is drawing a load per circuit also.
!972 K5 Blazer,Highlander,A/C a twin to the one I Had
1972 K/5 Blazer CST Highlander 15YR project
2003 Silverado Crew 2500HD (Daily driver)
1997 Ford focus (Beater)
2003 ford Taurus (student)
2014 Ford Fusion HYB (wife)
2003 Jetta ( Student)
2003 silverado is offline   Reply With Quote
