I have a Creeper gear transmission in my 67 C15 . I would like to swap that out with a Saginaw 4 speed. Can I just swap these out and keep the bellhousing,clutch assembly intact. Or is the splines different on the Saginaw?
Re: 4 speed Transmission interchange?
I am 98% sure the splines are the same.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
Spline should be the same but the trans input bearing housing diameter might be different.
Info in here. https://www.streetmusclemag.com/tech...t-bellhousing/ |
![]() Join Date: Mar 2003
Nose cone should be the same being an SM420. I would however check the bolt pattern
Tags |
saginaw 4 speed, sm465 |
