Old 05-18-2015, 07:33 AM   #1
Chrispbrown36
Original truck color?
According to the original sales slip from that 87 V10 the factory color was "29/90 blue/gray. What does the 29/90 mean? Does this specify how the two tone was done? (as in was the second color along the bottom or in the center) Eventually It has since been painted all blue, which I like but I would like to return it to its original color eventually.
Chrispbrown36 is offline   Reply With Quote
Old 05-18-2015, 07:37 AM   #2
Chrispbrown36
Re: Original truck color?
After posting this I did a little looking around and found out that the "29/90" refers to the color codes. So now my question is: Is there anyway to find out where the second color originally was? Was it based on model?
Old 05-18-2015, 10:11 AM   #3
Joesjunk
Joesjunk's Avatar
Here is an 87 I had last year, same color combo. The grey is like a steel/charcoal color, not silver.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 05-18-2015, 11:27 AM   #4
Keith Seymore
Keith Seymore's Avatar
It deciphers as 29U ("upper", or primary color) and 90L ("lower", or secondary color).
You have to know the two tone paint scheme (ZY2, ZY3, ZY4 or ZY5) in order to know if it was top/bottom, or inset.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-18-2015, 02:15 PM   #5
Chrispbrown36
That is exactly that I was looking for. "Special two-tone paint".....ZY3.....Paint code-29U......So, the ZY3 code means that from the black center molding up was one color and below the black molding was another. The 29U means that the blue was the upper color, which makes the gray the lower color. Thank you for the info.
Now I am curious what "23 W XDD1 Blue" means. Any ideas?
Old 05-18-2015, 02:41 PM   #6
Keith Seymore
Yah. It's the interior combination (color plus trim type/level). Blue "custom" vinyl bench.
Look on the chart I gave you, in the section above the highlighted area.
K
1979-1986
1986 - 2019
Old 05-18-2015, 03:09 PM   #7
D.FENS
Is there any info for 88 - 91 R/V series? The '88 catalog only shows GMT400 trucks.
My '88 crewcab was a red / white two-tone (red overspray in the jambs and under the hood) but was sprayed solid white at some point before I got it.
D.FENS is offline   Reply With Quote
Old 05-19-2015, 07:28 AM   #8
Keith Seymore
I agree; a glaring oversight, in my opinion.
This collection of brochures has '88 - '91 R/V truck info:
http://brochures.slosh.com/index.shtml?1988
For technical input (weights, ratings, option availability) you can still use the '87 GM Heritage Center archive generic information:
In fact, most of the time when I am getting parts for my truck I lie and tell them it's an '86 C/K, to avoid confusion.
K
1979-1986
1986 - 2019
