![]() Join Date: Aug 2004
64-66 Gauges with Tach
Nice factory Tach dash setup worked when I took it out.
275 plus shipping
65' Chevy C-10 Shortbox |
Re: 64-66 Gauges with Tach
I'll take it if still available.
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
sorry, may have jumped the gun... does the tach require a transmitter to work in '66 C10?
thanks
I don't know, pulled it out of a running 66 farm truck, everything worked fine 2 years ago, was going to use it myself, but going with a ls swap.
It worked on my old 66 farm truck just fine.
Anyone know??? Thanks
You'd need the model # of the back of the tachometer to know if it needs a box or not.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thanks,
Where is this "model #" ? I'm sure this will come up again.
Active Member
![]() Join Date: Aug 2015
Estimate for shipping to 29662?
![]() Join Date: Nov 2012
If it's in fact a '64-66 then it does not need a transmitter. It is also likely for an 8, not 6 cylinder. Take the cover off the back of the cluster and the tach will probably look like this original '65 8 cyl :
Shipping to 29662, about 21 bucks.
bump
250 plus shipping......
SOLD, thanks.
