Should I remove the front bumper to put new fenders on?
I had some trouble yesterday removing the inner and outer fenders (still joined) as the bumper seemed in the way.
Before I put the new fenders on, should I remove the bumper? Also, I assume the outer fender goes on first and then the inner fender? |
![]() Join Date: Jan 2007
Re: Should I remove the front bumper to put new fenders on?
Sounds like you answered your own question!
Remove the bumper, remove the inner fenders then the outers. Re-assemble in reverse order. If your fenders are aftermarket, they likely will not fit well and you will need to coax them together with the core support. That's a bit tougher with inners and the bumper on the truck.
I wait till the hood and everything is lined up and then put the inner fenders in
good luck
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
99 times of 100 I take the inner off with the outer, as the clips break and you need to lay it down on a bench to hold the broken[rusted] clips from the back with Vice Grips.
Putting the fenders back however you can put the fenders on then put the inners on the fender. It helps a BUNCH to take off the tire. Also you need to remove the bumper first before doing anything up front. I take them off right after the grille just to make things easier. Jim |
![]() Join Date: Dec 2013
yes you have to , or much easier if removed , same with grill
#8 | |
![]() I don't have a torch so I guess I'll rustle up a propane torch to heat up the nuts....I have a feeling my bumper bolts are not going to come off easily. Thanks everyone. |
#9 | |
![]() Join Date: May 2010
http://www.bernzomatic.com/item.html?id=30 |
