4WD Front hub question
Earlier today I tore down the front brakes/hubs on my K2500 to replace the rotors, and when I got everything apart I noticed that the right side had a shim on it that the left side did not. The shim was underneath the outermost piece with the dial in it. I'm assuming that both sides should have this shim correct? And are there supposed to be any gaskets or seals between the sections of the hubs? The last person to have this apart just put a thin layer of silicone, which worked fine, I'm just curious about the correct way these should be sealed up. Thanks for any info
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Re: 4WD Front hub question
That is one of two gaskets per side the factory used.
In this case the assembly manual would not be of any help but the service manual will be. If you don't have it here is a link to a usable free copy. RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 05-25-2015 at 04:23 PM. |
Thank you for confirming that Tim. I suppose nobody reproduces these either huh?
Carpe manana
![]() ![]() Join Date: Dec 2010
#1 is the metal gasket shown in the pic and #3 is the missing paper gasket. Neither reproduced and difficult to find.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Carpe manana
PM sent
![]() Join Date: Dec 2013
bigred76 if you cant round any up give me a shout I have a few down here
I was able to get the metal & paper gaskets on eBay. Thanks for the heads up DeadheadNM.
Carpe manana
Nice! Those were a good deal. Hats off to Kevin for stepping up with his offer. Glad you're set. Pete
