Turn Signal Assemblies Falls Out of Hood
Here is a really simple question. On my 1966 C10 both of my turn signal bulb assemblies fall out of the turn signal lens housing assemblies, when I close the hood. These are the newer white bulb assemblies from Oreileys, btw.
Am I missing a step for installation or what? If not then I am going to engineer something to keep them in place. Any great ideas? Thanks, Jason |
![]() Join Date: Jul 2007
Re: Turn Signal Assemblies Falls Out of Hood
Is it the bulbs or the whole lamp bezel?
king at the assy manual the inner housing bolt inside the hood and the metal trim bolts outside. Any photos of it?
There is a slot on the fitting that has to be lined up on the housing or it will not seat all the way. The notch will go towards the hood.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#6 | |
I pushed it in with the notch lined up, and seated it all of the way,but it still falls out. You would think that it would have an adjacent slot and notches on the assembly so you could line it up, push it in, and turn it. I have the dorman 85818 fitting....It had those before and I replaced them with the same thing. Are they correct? |
1961 crewcab
you say that they slide upward into the assemblies?
are your housings in upside down, because the bulb assembly should plug into the top of the housing.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Good eye Jon......make sure the holes face towards the top of the hood.
Hood is upside down here...but good reference pic on the assemblies installed
#9 | |
Chevy addict
Have you oiled your hinges and latch assembly? Don't slam the hood?
I have watched this happen time and again. I have seen reproduction sockets that are all steel, not plastic, not sure where to get them though. |
Now I understand the problem. The socket is falling out. You should be able to push straight in after lining up the slot . Make sure you did not break the clips or bend the metal contacts.
I probably have some OEMS ones I can send you if the problem persists.
he most likely has his lamps on upside down
I have only had this happen one time, never thought about the lamps being upside down!!
I'll be turning those over next time im playing under the hood. Hooligan
The Green Hornet 1960 Apache 10 Long Fleet - Driver and Work In Progress The Death Star 2006 Vstar 1100 - Chopped, Bobbed, Riding the Dark Side |
#15 | |
I'm going to go resituate them in a while. Thanks a lot |
#16 | |
I wonder if these are occasionally installed upside down by other, like mine were. I knew there was something odd that I was missing when I couldn't find information on google! |
#17 |
No problem and an easy fix. Be careful when removing the 2 screws that hold the housing on....there are nuts welded in the hood and I have seen them snap off. I'd spray them down and just go easy on them. Shouldn't take more than 5 min to reverse them.
