Shorting a Steering Column
I would like to know if any body has cut lets say about 3 or 4" out of a stock 72 auto trans steering column. Why might you ask would I want this done well like all of you know the D*m steering wheel is way too close and or my arms are too long and we all know the answer to that is BOTH are right. So lets here from some of you Engineering Genius's, I am pretty good with mechanical things so I am thinking the shorting area has to be done in the right place, I would think just under the shift lever housing and above the backup/ neutral safety switch would be the ideal spot right. what could go wrong? mjgord51
![]() Join Date: Oct 2010
Re: Shorting a Steering Column
There are write-ups on collapsing the intermediate shaft under the hood. You can gain some room with that. Best choice would be a tilt column. Here is one article:
http://67-72chevytrucks.com/vboard/s...d.php?t=309895
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
#3 | |
Not a current pic, I have a different steering wheel now, but shows how far the column is pushed in. ![]()
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
What Lattimer said
I don't think we get smarter as we get older. We just run out of Stupid things to do. |
Lattimer.... Any threads on how you accomplished this??
RAT1968 '68 Cab/'71 Parts
Try this. You'll be glad you did.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 07-17-2015 at 12:25 PM. |
