Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 08-21-2015, 03:22 PM   #1
F.A.A.benny
Rear A/C unit
SOLD
The entire system was pulled from a 72 Suburban. The unit was completely disassembled and all parts were gone through. The housing was cleaned and the Harrison sticker was applied again. The brackets were all bead blasted and repainted. . The evaporator was cleaned, flushed and pressure tested. The screan was cleaned. The expansion valve was disassembled, cleaned and reassembled. The hard line coming off the expansion valve was replated. The blower motor was bench tested, and repainted. The squirrel cages were reconditioned. The resistor was bench tested. New o-rings were installed as well as new screws. The wiring harness is in tact. I covered it with new electrical tape. Detailed the plastic plate that reads "rear ac". The switxh is included but not the knib. The complete drain hose set is included which consists of the correct drain hoses, hose clamps and correct grommets. The actual ac hoses are not included but the two fittings and hose clamps that connect to the unit are and have been replated if you want to retain a factory barb fitting connection. I will include the ac plastic cover if the winning bidder wants it. It does have some damge. A small piece is braken off in one corner but I have it I so desired. . The bezels that hold the registers in place have some cracks. The cover is pretty big and will add to the shipping. $300 plus shipping. LMK if you need any more pics.
F.A.A.benny is offline   Reply With Quote
