![]() Join Date: Sep 2013
New through the fender exhaust!!!!
Front of rear tire. Sounds great!!
71 LWB Large Bore 6-71 Blown 383 Stroker 4.11 Motive/EOM Eaton Posi Ported/Polished Carrier 15x8/15x16.5 MT Radials B&M Pro Shifter Truck Name- Spike |
Re: New through the fender exhaust!!!!
love it
Cool!
That looks good. How doyou keep it from rattling against housing?
#5 | |
Its 2 pieces. Its a marine thru tip thats mounted to the fender. Then we added the 3" tips to run thru that and the tips are welded in place and cut for whatever look you want.. Might put some flex pipe later but now no need.
Old member
Looks good Dennis!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
That looks real good.
Looks great.
looks good thats what i want to do to mine, except i want to do it at the back of rear tire . wonder if it will work
"Send in the clowns the goats are loose" |
Looks great. DO you have the link for where you got the marine tip?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
