Old 08-31-2015, 09:27 PM   #1
fleetmitch
fleetmitch's Avatar
1971 Factory Air Conditioning Hot/Cold Lever
What does the circled part actually do? How do I access it's connecting part(s)? Is it attached to a damper, and if so, is there a seal or rubber attached? Ultimately, could this part allow hot air to affect air conditioning / cooling?
fleetmitch is offline   Reply With Quote
Old 08-31-2015, 10:35 PM   #2
davischevy
davischevy's Avatar
Re: 1971 Factory Air Conditioning Hot/Cold Lever
Before you address that cable you need to run vacuum to the pod on the side of evaporator housing in the upper right corner of the pic.
The vacuum valve just in front of your circle needs to be hooked to the damper arm.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-01-2015, 11:08 AM   #3
Coley
Coley's Avatar
Smile Re: 1971 Factory Air Conditioning Hot/Cold Lever
Big ditto on this....as well as the other air/solenoid unit in the foreground which appears to be not only disconnected but wired into a certain position.
fleetmitch It looks like you've got to troubleshoot your vacuum lines on your a/c system before you dig any deeper. Without this vacuum control operating...and they currently are not hooked up....you won't be seeing much in the way of a/c.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-01-2015, 04:26 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1971 Factory Air Conditioning Hot/Cold Lever
If you take the cowl off you will see the flapper. It keeps outside air from entering the cab through the blower Motor. I have sealed mine off totally and took the vacuum line out. My AC runs great. It's on what the late models call MAX AC, not blend which is what you get when you have the flapper hooked up and operational. If the vacuum is not working correctly it will open and let hot outside air in + if it's all the way shut it's not a perfect seal. In other words your always adding fresh hot outside air to the AC system with the flapper opened any at all.
Just for good measure I have a manual hot water valve in line on my heater core to stop all water flow through the heater core. Any hot water coming through it to the cab will keep the temperature up inside the cab.
Here is another post we talk about it.
http://67-72chevytrucks.com/vboard/s...d.php?t=253275
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 09-01-2015, 02:34 AM   #5
F.A.A.benny
Here is a pic of the back side of the evaporator box so you can see what that rod attaches to
F.A.A.benny is offline   Reply With Quote
Old 09-01-2015, 06:01 PM   #6
Bigdav160
Bigdav160's Avatar
I think there is some confusion. The part the OP is asking about is the blend door (hot/cold). You can see the door in Benny's picture.
The vacuum motor is for the recirculating/fresh air door.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-01-2015, 07:50 PM   #7
davischevy
davischevy's Avatar
If there is confusion, I started the confusion. The valve/door he was asking about appears to be ok. I noticed the vacuum actuator for the cowl damper is not hooked up, and mentioned that.
other Larry
Old 09-01-2015, 08:26 PM   #8
Andy4639
Old member
Andy4639's Avatar
Not really confused. I figure he could figure out the cable by the picture posted. I was just giving him some more info on his AC for the vacuum canister if he wants to go that route.
