Old 09-21-2015, 07:33 AM   #1
chrismoore701
chrismoore701's Avatar
Heater Hose routing
I have a 1979 C10 with a 350, I have an easy way and a hard way to run my hoses. The easy way is to the radiator and to the water pump. Will this work?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 09-21-2015, 08:18 AM   #2
bmchevy1979
bmchevy1979's Avatar
Re: Heater Hose routing
They are supposed to go front of intake and radiator I don't believe you will get hot coolant from water pump I actually think that is a return on some older models
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 09-21-2015, 01:49 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Your heater is fed from the intake manifold (5/8" nipple)then returns to either the water pump or the radiator.
If your radiator has provision for a 3/4" heater hose hook up, use that and plug the water pump hole with the proper size plug.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-21-2015, 02:07 PM   #4
chrismoore701
I do have the nipple on the radiator, I just do not have access to the port on the intake. you can see the front passenger port is blocked by my fuel line, and the driver side port is blocked by the radiator hose. I can raise the carb and make adjustments, and it looks like I will have to. That is why I wanted to check. thanks guys
Chris
Chris
Old 09-21-2015, 02:09 PM   #5
chrismoore701
another pic
Chris
Old 09-21-2015, 07:46 PM   #6
Dead Parrot
Maybe something like this: http://www.globalindustrial.com/p/pl...FQ6HaQod3SkIpg installed on the driver's side pointed back toward the carb. Install the normal hose barb and run the hose between the thermostat housing and the carb.
Dead Parrot is offline   Reply With Quote
Old 09-21-2015, 07:55 PM   #7
Oldriginal86
The port in the radiator and intake manifold are the hot water supply to the heater, use only one. The water pump is suction and pulls the coolant from the heater. You should be good if you use the radiator as supply and water pump for return.
Oldriginal86 is offline   Reply With Quote
Old 09-22-2015, 01:29 AM   #8
BLE 'BURBAN
Not so sir. Coolant flows from radiator via lower hose and is pushed through the block and up through the heads to the intake manifold/thermostat. The coolant flows FROM THE INTAKE to the heater core thru 5/8" heater hose then back out thru a 3/4" heater hose to either the water pump or directly back to the radiator.
The COOLANT IN THE RADIATOR AND WATER PUMP IS ACTUALLY COLDER THAN THE COOLANT IN THE ENGINE/INTAKE
Going from water pump to heater and back to radiator will not get you any anything but headaches and frustration wondering why your cab isn't getting very warm in the winter.
Old 09-22-2015, 01:48 AM   #9
BLE 'BURBAN
Chris
I see your intake has 2 ports at the back just above the water jackets on the heads... get a 5/8" hose nipple with the proper size NPT thread to fit the one on the passengers side as well as two(2) 90* pre-formed 5/8" heater hose and a 5/8" heater hose union.
You can find the hose at Napa just make sure the short side is at 6-8" long to clear over your valve covers and the short end of the other onto the heater core, cut to length and join the 2 hoses together with the union.
And clamps....don't forget the clamps.
Old 09-22-2015, 07:23 AM   #10
chrismoore701
thanks for the ideas, I thought about using the ports in the back, but they are smaller than the front, will see how it goes. Will keep you posted
Chris
Old 09-22-2015, 08:52 AM   #11
chrismoore701
I found a 1” spacer on ebay for pretty cheap Should I get one with a single square opening, or one with four (4) circles to match the bottom of the carb? Is there any difference?
http://www.ebay.com/itm/1-Phenolic-C...e10bd5&vxp=mtr
http://www.ebay.com/itm/1-Phenolic-C...cf17c6&vxp=mtr
Chris
Old 09-22-2015, 11:20 AM   #12
nonstop
It almost sounds like your best bet, or at least easiest, would be a 90 degree heater hose fitting on the passenger side.
nonstop is offline   Reply With Quote
Old 09-22-2015, 11:32 AM   #13
Bigstevex4
Bigstevex4's Avatar
just swapped a 350 in for 6 it had hose connections on the pump. There was a port in the bottom off the block .Ran from intake to core to bottom block. Needed heat here couple weeks ago. Nothing. had bought a new rad it had 3/4 nipple. The intake port your blocking to core return rad good heat now 10 below well see?
83 c10 long Box Daily Driver
90 Jimmy parked
98 Road King/ 06 Road Glide
In memorium
63 impala SS/ 65 Chevy Panel
65 GMC Short Box/ 68 Camero
Bigstevex4 is offline   Reply With Quote
Old 09-22-2015, 05:13 PM   #14
chrismoore701
I think I need to raise it up any way to help with my vacuum line anyways. Which one you guys think will be the best?
Chris
Old 09-22-2015, 11:36 PM   #15
BLE 'BURBAN
Because your intake isn't fully open, go with the 4 hole spacer.
