Old 07-24-2015, 12:00 AM   #1
summitflier
summitflier's Avatar
Ignition key removal
Next question...
How do you get this thing out?
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 07-24-2015, 12:28 AM   #2
Jurassic-1
Jurassic-1's Avatar
Re: Ignition key removal
Locate the small hole in the right side next to the key hole. Put key in ignition and using a large paper clip insert it into the hole and you should feel a spring. Keep the clip pushed in and turn key and pull out at the same time. You then can remove the ring holding it in the dash.
Jurassic-1 is offline   Reply With Quote
Old 07-24-2015, 12:29 AM   #3
Custom/Ten
Custom/Ten's Avatar
What he said
Custom/Ten is offline   Reply With Quote
Old 07-24-2015, 12:41 AM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Suscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-24-2015, 01:01 AM   #5
leftybass209
leftybass209's Avatar
After you use the paper clip in the hole....
There is a tool that makes the removal of the bezel easy. I've never purchased it, but have used it once. I usually use a rubber coated spatula, or a flat blade wrapped with tape to spin the ring.
I suppose a spanner wrench could also be used to spin the bezel off.
leftybass209 is offline   Reply With Quote
Old 07-24-2015, 01:06 AM   #6
Jurassic-1
Jurassic-1's Avatar
When I answered I assume you have a key. If not you can get the old school small slide hammer and screw it into the key hole and yank the tumbler out then remove ring and switch assembly.
Old 07-24-2015, 10:08 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
You have to turn the ignition to the left as far as it will go "before" you insert the paper clip. The reason I always say that is because the late '68 - '72 ignitions have an accessory position and those have to be in the accessory position before inserting the paper clip. Also, once the cylinder turns to the left a little, you need to remove the paper clip or it may bind and prevent the cylinder from turning as far as it needs to go.... If you don't have a key take the passenger side door lock out and see if there is a code number stamped into it. The code number would look something like the one in the picture below. Take that to your local locksmith and have him cut a key from the code number.... If none of the locks have been replaced the key will fit the ignition.
LockDoc
Leon
Old 07-24-2015, 11:40 AM   #8
summitflier
I have a key
I will try it tonight. When I get home.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-24-2015, 12:21 PM   #9
clemsonteg
Don't turn it too far or it won't come out. I removed mine earlier this week and at first it felt stuck. After a few more tries I realized I could feel a small click and then I was going a little past that point which caused my issue.
clemsonteg is offline   Reply With Quote
Old 09-30-2015, 06:57 PM   #10
freak
Originally Posted by LockDoc View Post
You have to turn the ignition to the left as far as it will go "before" you insert the paper clip. The reason I always say that is because the late '68 - '72 ignitions have an accessory position and those have to be in the accessory position before inserting the paper clip. Also, once the cylinder turns to the left a little, you need to remove the paper clip or it may bind and prevent the cylinder from turning as far as it needs to go.... LockDoc
Thanks LockDoc!!! Got mine right out thanks to this post!!!
freak is offline   Reply With Quote
Old 09-30-2015, 07:51 PM   #11
LockDoc
LockDoc's Avatar
No problem. Glad it helped....
LockDoc
Leon
Old 09-30-2015, 09:12 PM   #12
toolboxchev
Das trikey!
Put straight wire in and follow instruction in chiltons, ugh no luck had to have a locksmith with his little hook pull the bugger out.
It may stick and the little hook trick is needed.
toolboxchev is offline   Reply With Quote
