Old 01-21-2021, 02:28 PM   #1
SCOTI
SCOTI's Avatar
Auto Tilt Lower Column Bearing
I have a 6x-72 era auto tilt column that required shortening for my custom application. I got the housing + shift tube whittled down to the length I need & ordered a 'new' lower column bearing kit from Crown Products (it's what popped up during my Google search) from Summit. In my search, I had 3/4" shaft included & it found #4487696K as the kit I needed. I looked it up & the consensus was it's a Jeep part that's common w/GM columns so I thought I found what I needed.
I got the part in & it's for a 1" shaft vs. the 3/4" I have. The bearing has no P/N etched into it & I'm not sure what 'type' of bearing it's technically called to help w/further searches.
Basically, I need the same outer dimensions w/a 3/4" ID. Any info/insight available?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
