Old 05-05-2009, 02:01 PM   #1
lks dcvn
lks dcvn's Avatar
Parts List Checklist - Camaro Rear Disc Brakes Using Glock's Brackets
Just getting my parts list together and wanted to confirm with anybody else out there who had done this - if I am on the right track...or if I have left something out - or if you have used something different/better that you could recommend. I will be placing my order this Friday and if you have any insight - let me/us know.
Thanks.
1. Glock’s Camaro Brake Brackets - $95
2. 93-97 Rear Loaded Calipers – www.RockAuto.com
a. Right A-1 CARDONE Part # 18B4540 (with mounting bracket) - $118.89 ($45 core)
b. Left A-1 CARDONE Part # 18B4541 (with mounting bracket) - $135.79 ($45 core)
3. Rear Rotors (94-96 Impala SS) – www.RockAuto.com
a. RAYBESTOS Part # 56450R {Professional Grade} - $27.79 each - $55.58
4. 93-97 Camaro Rear Brake Lines – www.RockAuto.com
a. (2) RAYBESTOS Part # BH380483 {Professional Grade} – (10.99 each) - $21.98
5. 93-97 Camaro Parking Brake Cable – www.RockAuto.com
a. WAGNER Part # BC133076 - $21.89
6. Metric Brake Line Adapters – www.gatewayfasteners.com – Part #1442 - $.99 each – $1.98
7. Disc/Disc Proportioning Valve - PVKS4 - www.classicperform.com - more specifically - http://www.classicperform.com/Store/...ruck/PVKS2.htm - $75
8. Hardware Needed:
a. (14) 3/8”-24x1-1/4” Grade 8 bolts – Tractor Supply Company – Bulk Bolts
b. (14) 3/8”-24 Grade C nuts – Tractor Supply Company – Bulk Bolts
c. (14) 3/8” hardened flat washers – Tractor Supply Company – Bulk Bolts
d. (4) M12-1.75x25mm Grade 10.9 Bolts
e. (8) M12 flat washers
lks dcvn is offline   Reply With Quote
