Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-30-2014, 02:06 PM   #1
Pacific Fabrication
Pacific Fabrication's Avatar
'67-'72 GM Truck LS Engine Crossmembers
If you're swapping an LSx motor into your '67-'72 GM truck, you probably see that the factory crossmember just doesn't fit. To ease your install we have a bolt in replacement piece we've developed.
This unit was developed using computer aided design and is cut out on a CNC plasma table for great fit and finish every time. The crossmember is made from 1/4" mild steel plate and is welded in house. It ships with all the grade 8 hardware needed for installation as well as a new set of rubber motor mounts and adapter plate to mate to your new LSx engine.
$399
Pacific Fabrication is offline
