Old 10-23-2015, 02:03 AM   #1
DustyNova
427 Crew cab mpg question
What do you guys usually get for 427/454s in your crew cabs?
DustyNova is offline   Reply With Quote
Old 10-23-2015, 03:09 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 427 Crew cab mpg question
87 cc dually,454/TH400 RWD running stock size 215/85R16 and 4:10 rear end gears on the highway I was lucky to get 7-8 mpg.
Swapped out the rear end gears for a set of DANA/SPICER 3:54's as well as a GEARVENDORS OVERDRIVE UNIT which when engaged gives me the equivalent of a 2:77 rear end.
Highway mileage is now 15-17 mpg depending on how much lead has filled my go-pedal foot.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 10-23-2015, 09:30 AM   #3
SCOTI
SCOTI's Avatar
8-9mpg's on the factory motor in my 89 (454/th400/4.10's/no OD/235-85-16's).
It's rebuilt now but haven't done highway miles to see if things are better now that it's fresh.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-23-2015, 09:34 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
Even the newer FI engines get bad mileage. My 99 with overdrive and 3.73 never gets better than 12. Its usually 9-11. But it stays at 9-11 when I tow.
If you buy a big block truck, you're not buying it for fuel mileage. I tell myself that every time I put gas in it.
95 S_Trucker is offline   Reply With Quote
Old 10-23-2015, 02:18 PM   #5
jjmorrse
I think it is easier with the monster to measure in terms of gallon per mile,which is about 0.2 gpm
jjmorrse
86 C30 crewcab big dooley. 454- 400
jjmorrse is offline   Reply With Quote
