Old 10-26-2015, 09:18 AM   #1
Banjo
bed removal wiring disconnect on 66
Hello have all my bolts undone on my 66 fleet, and unsure exactly how to disconnect rear wiring. I want to remove the bed to install a rear gas tank and new wood, and this is my first bed removal. I'm just not warm and fuzzy about the wiring disconnection part? Also, does the ignition switch ground through the metal dash on my '66? THANK YOU!
Banjo is offline   Reply With Quote
Old 10-26-2015, 10:07 AM   #2
SnS C10
SnS C10's Avatar
Re: bed removal wiring disconnect on 66
Hey banjo I just did my first bed removal on my 64 last night. The wiring on my truck runs up the driver frame rail and is simply disconnected at the connector right next to the driver rear tail light. After that is disconnected and the bolts are all loose, the bed can be lifed off
SnS C10 is offline   Reply With Quote
Old 10-26-2015, 10:32 AM   #3
PGSigns
PGSigns's Avatar
Look right at the end of the drivers side frame rail and where the rear crossmember is mounted. There will be a rubber plug on the end of the wiring pushed into a hole in the cross member if the wiring harness is stock. Will be very close to where the bolt comes through the rear bed sill.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
