Old 11-08-2015, 12:33 PM   #1
solidaxel
solidaxel's Avatar
M A P 2003 Tahoe 5.3
I am in need of a new M A P sensor is there one better than the other
I lookedthem up and they range from 5.00 to 120.00 with the same part number
I am thinking somewhere around 50.00 and A C Delco the part number on my M A P is 09359409
Is there a better one out there or is the "less expensive" one any good?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-08-2015, 07:36 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: M A P 2003 Tahoe 5.3
I have a old S-10 MAP and was wondering the same thing. It looks just like the one on my 6.0!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-08-2015, 08:03 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Delco/Delphi is the way to go.
BTW, you can get a TMAP from a j-body and some of the older 3800 cars as well and it will swap direct. The MAP scale and functions are the same, but it has an additional temp input that can be used for IAT2 or in lieu of the temp sensor in the MAF.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-08-2015, 09:04 PM   #4
solidaxel
solidaxel's Avatar
Thanks, do you have a, part number !!!
LS 3 4L70E
